05-22-2017
17:38
17:15
05-22-2017
17:38
17:15
My flex 2 charges and counts steps but it does not light when tapped. I saw a similar post that was solved by letting it charge overnight. I have done this and it did not solve the issue. It does vibrate when I put it in the charger.
05-22-2017 20:49
05-22-2017 20:49
Try restarting it and see if that solves the issue. If one restart doesnt do it, try doing three in a row. Does it show lights ever? Let us know how you go. If it has no lights and they dont come on after the restart/s then you will need to contact Customer Support
RESTART PROCEEDURE
Put your tracker into the charger so it has the charging lights showing. Then press the small button on the back of the charger 3 times within 5 seconds. It will vibrate with each press and then when all three are done it will very briefly flash all lights and then go back to charging lights and it is all done
Full instructions
http://help.fitbit.com/articles/en_US/Help_article/1186
Helen | Western Australia
05-22-2017 20:49
05-22-2017 20:49
RESTART PROCEEDURE
Full instructions
05-24-2017 10:41
05-24-2017 10:41
Thank you this worked.
Best Answer05-25-2017 00:15
05-25-2017 00:15
Yee haaa! Fantastic 👍
Best Answer09-23-2017 05:20
09-23-2017 05:20
Same thing happened to me, your solution worked!
Best Answer09-23-2017 08:52
09-23-2017 08:52
@Eel499 That is great!
Best Answer11-30-2019 02:03
11-30-2019 02:03
Thank you so much. I was despairing, this worked after 4 presses. Brilliant
