06-05-2017
11:45
17:15
06-05-2017
11:45
17:15
Hello,
The past week or so my fitbit has said I've burnt exactly the same amount of calories each day (1535), but the amount of steps I've done has varied from less than 2000 (due to illness) to more 8000. Also, my normal average calorie burn is usually a lot higher even on sedentary days at an average of 1800.
I use both a charge HR and a flex 2, and this problem seems to happen regardless of whether I've been wearing just one type of fitbit or swapped throughout the day.
Thanks,
Holly
06-07-2017 02:49
06-07-2017 02:49
That sounds weird! You could try uninstalling the App, restarting your phone and reinstalling the app. Not sure if that will work or not, but worth a try.
Helen | Western Australia
06-07-2017 05:03
06-07-2017 05:03
I gave this a go and it's still showing 1535 calories, even though before I went to bed last night it was at 1,900. It just seems to reset to 1535 each day
06-07-2017 05:25
06-07-2017 05:25
Really strange! I'd suggest you contact Support. See if they can shed some light on it!
06-18-2020 20:33
06-18-2020 20:33
I have the exact same issue( restarted app. It worked ok for one day but is doing the same again.
