05-10-2017
23:20
17:15
05-10-2017
23:20
17:15
Everything working OK in Uk. Have arrived in Albania and nothing was syncing. I logged out of Fitbit and now I cannot login. Keeps saying 'down for maintenance'
Have reinstalled, rebooted - nothing works. Am using app in Samsung 7.
05-11-2017 22:33
05-11-2017 22:33
Then I guess it is down for maintainance! Hope you are back on line soon ☺
Helen | Western Australia
08-06-2019 04:23
08-06-2019 04:23
Did you ever solve your problem. I am finding something similar here in Albania - can't sync. Any advice?
Best Answer08-06-2019 05:00
08-06-2019 05:00
Try uninstalling the app, reinstall it and log back in. That generally seems to solve the problem, unless the problem is with the internet
08-06-2019 05:18
08-06-2019 05:18
