09-09-2021 05:03
09-09-2021 05:03
My flex wont stop counting. Have reset,reinstalled app. What can i do?
09-10-2021 06:15
09-10-2021 06:15
Happy news @Shelbyhelp ! Thanks for the update. Now you can get back to stepping.
09-09-2021 06:48
09-09-2021 06:48
Hi @Shelbyhelp the app wouldn't be the problem, but it seems your Flex might be. Try restarting it a few more times. The Flex is getting older, I'm sure, since it was retired quite some time ago. Usually restarting fixes simple glitches, if it doesn't work, there might not be a way to get it going properly again.
09-10-2021 05:23
09-10-2021 05:23
Thank you. Kept trying reset& charging a few days. Even removed flex & reinstalled & it finally reset & is working!
09-10-2021 06:15
09-10-2021 06:15
