02-21-2020
05:24
17:08
02-21-2020
05:24
17:08
My fitbit has started to miss off details of walk in the section that tells you how long you have walked each day in the exercise section. It still records the full amount of steps in the circle part....help please
02-21-2020 23:29
02-21-2020 23:29
Hi @AnneField Try restarting it several times. If that doesnt fix the issue, uninstall the app and then reinstall it and hopefully that will do it.
Helen | Western Australia
Best Answer02-22-2020 01:00
02-22-2020 01:00
Best Answer02-23-2020 08:22
02-23-2020 08:22
I tried restarting my flex2 it seemed to be a short term solution. It is back to not recording accurately again and now I am noticing that it is not acting compatibly with the challenges as well. My results in the challenges are now not updating, as well; which takes away the fun of participating in the challenges.
Best Answer02-23-2020 17:54
02-23-2020 17:54
@LMB25 Try uninstalling the app from your phone and then reinstall it and log back in. It is possible it is an app problem.
Best Answer02-23-2020 18:36
02-23-2020 18:36
Best Answer02-23-2020 19:38
02-23-2020 19:38
Ok thanks for that. If the issue continues Id suggest you contact Support
