03-05-2020
16:03
16:54
03-05-2020
16:03
16:54
I have a Fitbit Flex that has not been paired for quite some time. When I try to pair it with the app it says "The operation couldn't be completed. (com.fitbit.HTTP error 400.)" I've also tried pairing it with my Mac and the dongle. How can I get this Fitbit paired?
03-23-2020 11:25
03-23-2020 11:25
Hi @C20,
Have you tried resetting the Fitbit and then setting it up as a new device?
one cruise ship at a time!
Best Answer03-23-2020 14:24
03-23-2020 14:24
I don’t know if anybody else has tried setting it up as a new device, but I just did and it did not help at all.
Best Answer04-08-2020 16:03
04-08-2020 16:03
@C20 are you trying to pair the tracker through the phones Bluetooth. This can not be done.
If your tracker is still connected to your Fitbit account, then open the fitbit app, log in, your good to go.
If not connected to your Fitbit account. Then add the device.
Best Answer04-22-2020 19:21
04-22-2020 19:21
Hi, did you have other fitbits on your account? you may have to remove all the other ones, add the Flex, and put the others back on. Mine did that to me 😉
Good luck!
Best Answer04-22-2020 23:23
04-22-2020 23:23
If I reset my Flex will I lose all my badges?
Best Answer04-23-2020 11:19
04-23-2020 11:19
