01-18-2022
00:40
12:10
01-18-2022
00:40
12:10
Hi. First time on this. Needing some help please with my Flex.
The lights show up on the tracker when charging and will sync when tracker charginging.
However when I put the tracker in the wristband, lights will not show when tapping.
I have not used it for quite some time.
Am I doing something wrong or ha\s my tracker had it? I hoping not. Thanks in advance.
Hi @keltrev lithium ion batteries don't like not being used so your flex 2 battery may have died. But before you come to that conclusion, try restarting it a few times. If that doesn't help then it has died.
Helen | Western Australia
Hi, this seems to be a problem for me as well. I have bought this Flex 2 tracker, brand new.
I have had it in the charging port for 2 hours. I have set it up while charging. It glows 1 white light. When I attempt to restart (3 clicks), I only see a flash (half a second) of 5 white lights, then goes back to the slow glow 1 white light. This is the same no matter how many times it is done.
If i take it off the charger, there is no light whatsoever.
When I look at the app, and refresh the connection (whilst charging), the app says the battery is at 0% (empty battery with a slash-icon).
