09-23-2021
05:50
12:46
09-23-2021
05:50
12:46
Since I did a system update on my phone on 9/12/2021, my Flex 2 won't sync or record any data. I've tried everything to get it to connect to Bluetooth and it keeps saying that I need an app to connect. I have the app! Soooo frustrating!!!!!!
09-23-2021 07:00
09-23-2021 07:00
Hi @Victory7983 what operating system is your phone?
09-23-2021 17:07
09-23-2021 17:07
I have an Android. It was updated to version 10.
Best Answer09-23-2021 20:04
09-23-2021 20:04
Have you seen this article on trouble syncing? click to read
09-24-2021 15:44
09-24-2021 15:44
Yes....and I've tried every suggestion for Flex 2 for Android phones. It seems to hopeless.
Best Answer09-24-2021 16:35
09-24-2021 16:35
@Victory7983 you tried everything? Then you might want to get with support, which is linked on that page at the bottom
09-25-2021 05:39
09-25-2021 05:39
I'll do that...thanks for your responses.
11-11-2021 04:15
11-11-2021 04:15
Did you get anywhere? I'm in the same position. Last sync mine was 9/3. I've tried the suggestions also, but nothing..
Best Answer11-11-2021 09:01
11-11-2021 09:01
Flex (1) has same issue. No logging since 11/09 and it will not even try to sync.
Best Answer11-11-2021 09:44
11-11-2021 09:44
I never got my Flex 2 to work again. Only thing I can think of is that it's not being supported by Fitbit anymore. So, I think Fitbit should send us a new device, free of charge, that works, right?!
11-11-2021 11:00
11-11-2021 11:00
@Victory7983 did you get with support? These devices are getting old. The Flex was discontinued when the Flex 2 arrived. Both of those were replaced by the Inspire series at least two or more years ago. Your Flex 2 is supported, but there is no warranty on it. I can't see how Fitbit would give new devices to people whose older ones stopped working.
Best Answer11-11-2021 11:20
11-11-2021 11:20
Best Answer11-11-2021 12:51
11-11-2021 12:51
@Mikelarry305 without the charger, you can't restart it either. You posted in August asking about the charger. You can buy a charger - did you try?
