12-30-2019
18:59
17:15
12-30-2019
18:59
17:15
I got a Fitbit flex 2 as a gift 2 days ago. I have kept it for charging for more than 8 hours, while charging only 1 light is blinking, but in the fitbit mobile application it is still showing 0 % battery ??
Can you please help me ?
12-31-2019
07:16
07:00
12-31-2019
07:16
07:00
@SunilMK24 Welcome! It's great to see you around!
Let me help you with your Flex 2 not charging. Try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device and see how it behaves. You can follow these instructions to help your tracker charge.
Let me know how it goes.
