10-20-2020 17:19
10-20-2020 17:19
My flex isn’t syncing correctly. My Fitbit on my phone shows up as .... can’t find device . I’ve shut off my phone, update settings , turned Bluetooth both off and then back on AND trued to live chat and conventionally the chat list connection. Any help would be greatly appreciated
10-20-2020 18:34
10-20-2020 18:34
Hi, I had the same problem yesterday but I got it to work today. Use a paper clip and press the little hole on the back of the charger for 3 seconds. Do it 3 times and see if it works.. good luck.
10-21-2020 07:19
10-21-2020 07:19
This happened to me too no matter what I tried it wouldn’t sync I’ve had to reinstall and now have lost ALL of yesterday’s steps 😢😡😡
10-21-2020 11:48
10-21-2020 11:48
I can’t see a hole in back of charger (and yes I’ve got my glasses on!) my flex isn’t syncing either
10-23-2020 17:07
10-23-2020 17:07
Neither can I!! Wat do I do please??
10-24-2020 14:06
10-24-2020 14:06
I did all that. Reinstalled the app. Now, the entire step icon is GONE from the dashboard.
10-24-2020 16:06
10-24-2020 16:06
To all who are having trouble with the paperclip solution, it does work. At least it did for me. The problem is the terminology: it's not the *charger* that has the hole for the paperclip; it's the dongle (that is, the cord that your fitbit slots into that plugs into the usb charger on the other end). If you turn it over, you should see a tiny little hole on the back side of the end where the fitbit fits in. First, make sure the fitbit has a decent charge. Then:
1. Turn off the fitbit app on your phone or tablet.
2. Plug everything into the charger as if you were charging it, and insert the fitbit.
3. Grab a paper clip and insert it into the hole in the back, pressing until it makes contact.
4. Hold the pressure for 3-4 sec, then release.
5. Open the app again. If all went well, your steps should update.
And am I the only one reminded of the paperclip restarts of our laptops 25 years ago? Sorta made me nostalgic....
10-24-2020 16:08
10-24-2020 16:08
Hi Rob -- if you're still looking, I just posted slightly more detailed instructions above. Hope it helps! 🤞
10-25-2020 02:31
10-25-2020 02:31
We have tried this. It works for a few minutes, then quits working. You have to do it again with the charger and paper clip to reset. We shouldn’t have to keep resetting. Something is wrong within Fitbit especially if we are all having to do this.
10-25-2020 16:13
10-25-2020 16:13
Thankyou, spent ages trying to find 'the hole'. I followed your instructions and now my flex is back syncing 🙂
10-25-2020 18:12
10-25-2020 18:12
I have examined my fit bit and the charger and am not finding anywhere that I would actually stick the paper clip in. Am I correct that it's not in the Fitbit itself but rather the charger piece? I feel like an idiot searching for it and not finding anything. I've even had my teens help me w/o success.
10-25-2020 18:22
10-25-2020 18:22
My step icon vanished too. I have "stairs" but no steps
11-02-2020 09:07
11-02-2020 09:07
I have 13.7 IOS software. Turn off Bluetooth on FitBit in Settings. Then place tracker in charger. You’ll see reset hole on charger. Use paper clip & press 3 seconds three times.
Turn Bluetooth back on.
Finally after trying for 2.5 weeks different suggestions. This one works! 👍😀
Didn’t uninstall time avoid lost data. Good luck
11-11-2020 18:43
11-11-2020 18:43
Thank you, this worked for me also. dlc8
11-13-2020 14:07
11-13-2020 14:07
Thank you. I did sync my fitbit flex but I lost my steps for the day. I have to say, prior to reading this board I had contacted fitbit 3 times and all they did was ask if I had updated my fitbit app and/or my mobile phone. I did do an overkill though, got my flex to charge of my PC while adding the "wiget" to sync the flex to the PC AND open up the fitbit app. The lights went dark all of the sudden and then it said it had synced the device. Thank you.
11-14-2020 20:45
11-14-2020 20:45
I cant either any luck??
11-14-2020 21:08
11-14-2020 21:08
I see no hole.... wait i do now.... let me see it it works... it keeps tracks of steps but does not sync i tried to redo it like i am setting up a new fitbit and nothing
