No reset button
ANSWERED
I have read about resetting the flex by using the hole on the back of the charger and unless I'm blind, I don't have one. Please help!
1 BEST ANSWER
Accepted Solutions
It's not very easy to spot. Have a look at this thread that has a picture showing where it is:
https://community.fitbit.com/t5/Flex/Reset-button/m-p/659613
If it's not there then I wonder if your charging cable is a fitbit original. Some 3rd party replacement cables do not have the restart hole.
3 REPLIES 3
Thank you for that answer. Definitely no hole so can only presume not a genuine fitbit charger. Will now order a new one to hopefully solve the problem. Thanks again SteveH
I get access denied from this message - bummer
