Silent Alarm settings missing from app
I use my Fitbit vibrating alarm for my daily wake up due to hearing loss.  Just did the update suggested and now the alarm feature is gone.  How do I get it back. I will be lost without it.
59 REPLIES 59
On the main "today" tab of the dashboard, select your profile image at the top left of the screen, then select your fitbit. You will then be on the device settings where you'll find the alarms
Same with me!  Got the app update that was offered yesterday and now have no silent alarm feature.  What do I do?
Thank you!  That worked!
Sent from Yahoo Mail for iPhone
This does not work for me. There is no listening for alarms. What do I do?
Yeah, I've followed three instructions to click on today, my profile, my device,  there is not a silent alarm option for my versa 2. PS I was able to find it a week ago when I was using a charge 3, but since I've switch devices, it's missing.
@Osutuffy those instructions work for the Charge 3 as you need to set up alarms for that in the app. But, for the Versa 2 you manage alarms on the fitbit itself so the option isn't there in the app. Swipe left on the main screen of the Versa 2 until you find the "alarms" app.
I got charge 4 and I don’t have silent alarm on the app. I can set them on the device, but why I cant on the app????
@ekelvin that was just a design choice by fitbit
There is a feature suggestion asking for the alarms to be managed on the app as well. If you'd like to add your vote you can find it in the link below, but note Fitbit's comment that they don't currently have plans to make this change. Perhaps with more votes they will reconsider:
https://community.fitbit.com/t5/Feature-Suggestions/Add-Edit-or-Delete-alarms-from-the-app-for-new-F...
Thank you for coming back so quickly.
I am very old user of fitbit and was expecting it on the app which is much faster to manage.
I can say that not finding it in the app was quite confusing for me and considered a bug.
The normal expectation is for new products to have more features in the app, not the opposite.
To product owners: a bad design decision.
I have Charge 3 and this method doesn't work for me. Used to have Silent Alarms but now it's gone
@Tdatt the software update for the Charge 3 that's being rolled out at the moment has moved the Silent Alarms from the fitbit app on your phone to the Charge 3. Have you checked for a new Alarms app on your fitbit?
Yes I can set the alarm on my Fitbit. Thanks for your help!!
It has been moved to the Fitbit itself. It is easy to add. Swipe to find alarms, tap on hour first, scroll to the hour you want, then do the minutes. I was very annoyed when it was removed from the app.
Thank you so much !  That was the trick !  You would think they could put something out telling you the changes they made.  You helped me to finally stop chasing my tail.  😄
Glad to help, be sure you set am, pm, I obviously did pm and now I have to figure out how to change it.
Sent from my iPad
If you haven't figured it out already, after I set the time it prompted
am/pm and I scrolled up or down for the proper setting. Thanks again !
Thank you!!!  I used to do the silent alarm right from my app.  After reading this I see now it is actually on the Charge 3 itself.   Fingers crossed it will wake me up tomorrow!!
Be sure to choose AM.
Sent from my iPhone
