08-12-2019
14:35
17:15
08-12-2019
14:35
17:15
I use my Fitbit vibrating alarm for my daily wake up due to hearing loss. Just did the update suggested and now the alarm feature is gone. How do I get it back. I will be lost without it.
08-24-2020 06:48
08-24-2020 06:48
Hi I have tried that and no setting for alarms. Thank you
08-27-2020 04:52
08-27-2020 04:52
Thanks for the info, but I do not like working with the tiny screen. Anyway, since the update, I have not had time to find the silent alarms because I am constantly having to repeat pairing with my iPhone 11. The latest update has caused too many problems and Fitbit dropped the ball by not notifying customers about the changes. I am no longer a satisfied customer.
08-29-2020 11:11
08-29-2020 11:11
What about getting it on my iPhone Xr. That's where I set and delete it for my tennis matches that are times. rarely use my laptop to set anything anymore for fitbit
08-30-2020 13:38 - edited 08-30-2020 13:42
This is an example for bad design decision, Removing alarm option from app. You dont have big screen on charge 3 to easily navigate through options to set an alarm. Why not have option available on both App & device
08-30-2020 13:46
08-30-2020 13:46
I could not agree more, Kaltej.
08-30-2020 23:19
08-30-2020 23:19
Best Answer09-01-2020 08:02
09-01-2020 08:02
Sorry, no alarm option after following these simple directions. Supposedly setting alarms is now done on Charge 3 itself. There is no option for alarms on my Charge 3 either. Have updated phone, restarted Bluetooth, synced devices, charged Charge 3; still no "alarm" option available.
Best Answer09-07-2020 16:55
09-07-2020 16:55
I’ll just add my thoughts to the rest.
Amazing stupidity in removing the feature of setting silent alarms from the app.
Equally thoughtless to not properly inform about it.
09-08-2020 12:34
09-08-2020 12:34
For the first time in several years, I am looking at other companies’ options to record my exercise and sleep. Fitbit’s customer communication is lacking, and I do not believe my Charge 3 is as good as my Charge 2. I do not want to spend my hard earned money to buy a Charge 4 and be disappointed with it.
After this silent alarm fiasco, I believe Fitbit will lose many customers, including me!
09-09-2020 07:24
09-09-2020 07:24
How do I get silent alarms back on my Fitbit app? It’s disappeared!
Best Answer09-09-2020 07:28
09-09-2020 07:28
Best Answer09-09-2020 08:38
09-09-2020 08:38
Best Answer09-09-2020 10:26
09-09-2020 10:26
Best Answer09-09-2020 10:32
09-09-2020 10:32
Best Answer09-09-2020 11:52
09-09-2020 11:52
Best Answer09-09-2020 14:37
09-09-2020 14:37
Tried that it’s not there any more after updating?
Best Answer09-11-2020 06:06
09-11-2020 06:06
not since the update.
Best Answer09-15-2020 23:11
09-15-2020 23:11
I have no alarm setting on my phone or my Fitbit since the update
Best Answer09-27-2020 01:26
09-27-2020 01:26
I agree, it is a very poor piece of UX design. The Charge 3 is not a great place to modify settings.
Best Answer02-14-2021 08:31
02-14-2021 08:31
Thank you - you just saved me from buying a new fitbit - I LOVE my FLEX 2!!!
