12-19-2016
06:01
16:59
12-19-2016
06:01
16:59
hi, i put my flex on for the first time in ages and been wearing ir for a few days now but for some strange reason it wont sync. i cant even find how to sync it manually, iv tried restarting it, uninstalling the app on my phone but nothings worked, iv even tried with the new updated version and that hasnt got anywhere to manually sync. im really annoyed now, please please help, thanks, Tracey
Moderator edit: I have moved your post to the Flex board to increase the chance of getting a response.
12-19-2016 07:06
12-19-2016 07:06
If you havent used it in a while do you have the Dongle Plugged into a USB Port on your compuetr?
It needs to be to sync to the computer
Wendy | CA | Moto G6 Android
12-20-2016 09:04 - edited 12-20-2016 09:05
Have a great day @Tracey1967! Thank you for jumping in @WendyB. I'd like to add that if you're still having syncing issues with your Flex try the next steps to fix the issue:
If you encounter any issue let me know with details, so I can further assist you. But I'm pretty sure that these steps will do the trick. ![]()
Note: Make sure your phone and Fitbit App are up to date. And for Android phones take a look of this tips for syncing from @ErickFitbit! ![]()
Have a good one! ![]()
12-20-2016 11:43
12-20-2016 11:43
I'm having the same problem. I've worn mine consistently though. Three days ago it stopped syncing and saying the battery was dead when it wasn't. Today I contacted Fitbit and was told there's nothing that can be done and I'll need a new one. They offered to give me a 25% off code via email. It's been at least 5hrs and I have yet to get this email. I think it's one of those things where when a new model comes out and all of a sudden the old one stops working.
12-22-2016 21:55
12-22-2016 21:55
When did you upgrade the firmware for your fitbit? Recently? Same happened to me after upgrading this week and then after my fitbit died it would no longer sync
12-22-2016 22:34
12-22-2016 22:34
Well, I think I figured out the problem with my syncing issue. I hadn't used mine in about a year. It worked and I updated the firmware, but let it die because of odd recharging issues (I still don't understand why it's being so finicky). I tried using the dongle on my laptop, old and new versions of android, and every proceedure fitbit had written about. The key source of the problem is that I let the battery die completely, which needed a reset to remedy.
I thought I had been resetting my fitbit, but wasn't. A quick Youtube video showed me what the lights were supposed to look like and I got it. The key is that the reset has to be done while charging with blinking lights. Just because it was plugged in doesn't mean it's actually charging. I wasn't sure if the update changed things, but I had not been able to get the blinking 4 lights as I had remembered they did. I finally got the lights by plugging the fitbit charger into my USB phone charger in the wall. When I got the 4 blinking lights I reset with a paper clip. Viola! All my frustrations subsided. In all this was a massive waste of time today and I almost threw it away. I'm glad that I finally figured it out.
12-23-2016 12:34
12-23-2016 12:34
12-24-2016 08:45
12-24-2016 08:45
It's nice to see you in the Forums guys! ![]()
Sorry to hear that @KatLopes, thank you also for the feedback provided. If your Flex is not dead and you want to keep troubleshooting I'd like to know if you're getting any error or specific screen when you disconnect your Fitbit Flex from your Account and try to set it up again. Which device are you using? Did you update your phone or Fitbit App recently? This information is very helpful to further assist you! ![]()
Thanks for your second post with all the details about the troubleshooting steps that you've tried @NathanK, it's great to know that you're back on track! ![]()
@Tracey1967 To add back your step tile tap on "Edit" in your Fitbit app, (scroll all the way down and you will see the option). Let me know how it works for you! ![]()
Have a great day and Happy Holidays!
12-25-2016 07:43
12-25-2016 07:43
12-26-2016 05:12
12-26-2016 05:12
Hey there @Tracey1967, good morning! I would like to know if your're trying to see steps from an iOS/Android device or from a PC/Laptop so I can further assist you, I can not see the pictures in your previous post. Can you send them again. ![]()
I'll be waiting for your response! ![]()
12-27-2016 02:13
12-27-2016 02:13
12-27-2016 04:31
12-27-2016 04:31
Good morning @Tracey1967! Thanks for getting back to me, it'll be great if you send those pictures. Have you tried to log out and log back in into your account. You can log into you old account to keep your trophies and all previous data and try set up your Flex in that account. If your Flex is not responding try the restart. So the steps would be:
I think that you will have all your data after syncing it.
Let me know if this helps! ![]()
06-10-2019 19:45
06-10-2019 19:45
Hi! I have been having issues with my flex2. It recognizes the minutes of exercise but does not update the "track exercise" tile. This is an ongoing issue. There are at least 2 or 3 days a week that this tile is not synced. I have tried different methods suggested here (restarting the phone, reinstalling the app etc) but nothing seems to work. Any other suggestions? Thanks!!
Best Answer06-10-2019 23:28
06-10-2019 23:28
