12-13-2019
08:36
17:15
12-13-2019
08:36
17:15
It seems my dongle goes to a disconnect mode (! displayed). The only way to reconnect is a reboot and then synch. Is there a fix .. its a pain to reboot just to synch.
12-23-2019 08:55 - edited 12-23-2019 08:56
@stepbill Welcome! It's nice to have you on board! Sorry for the delay in my reply.
Let me help you syncing your Flex 2 with your iMac. Have you tried using your computer's device manager to turn off bluetooth connections or use a different usb port? It is odd that your computer stops detecting your dongle still I suggest you try using your computer's bluetooth chip if it has one or use a phone to sync your tracker.
Let me know how it goes.
Best Answer12-24-2019 21:18
12-24-2019 21:18
@AlvaroFitbit is the Fitbit dongle still needed with the Mac?
