02-19-2015 15:02
02-19-2015 15:02
Hey All,
I have only made rabbit a handful of times but never found a recipe I liked until last night. I basically cut the ribcage of a young rabbit to splay it in a baking dish and salted and peppered both sides. Then I mixed a little olive oil in a small ramekin with crushed dried rosemary and minced garlic and rubbed the whole rabbit down, making sure to get the mix on all parts. Then I baked at 450*F/230*C oven for 30 minutes. Easy and delicious! A good side is mixed carrots/onions/potatoes coated with hebes de provence in the same dish or oven.
Okay I showed you mine, now you show me yours. Do you guys have tasty recipe suggestions for rabbit?
02-19-2015 15:56
02-19-2015 15:56
I like to roast rabbit in honey garlic sauce. Mmmm.
02-19-2015 20:23
02-19-2015 20:23
Thanks Urchin. Do you mix water with the honey and what ratio if so? I never really think of honey on meats, but perhaps I should give it a try.
02-20-2015 10:38
02-20-2015 10:38
I actually just buy a jar of VH honey garlic sauce. http://www.vhsauces.ca/product-detail/Honey-Garlic-Cooking-Sauce-25.aspx?lang=en
It is really yummy!
03-28-2015 22:28
03-28-2015 22:28
05-22-2015 10:40
05-22-2015 10:40
Wow, @SunsetRunner, that does sound amazingly delicious and simple enough to do over a campfire. I will definitely try this - thanks!
Best Answer05-25-2015 17:12
05-25-2015 17:12
@kelfran I'll try this recipe, I never heard of this before. ![]()
08-08-2015 15:59
08-08-2015 15:59
Rabbit in mustard Sauce.
08-09-2015 05:47
