01-09-2021
04:07
21:22
EstuardoFitbit
01-09-2021
04:07
21:22
EstuardoFitbit
Hello,
any tips on making the green lights work again on my inspire 2? I have had it for 3 weeks and the lights just stopped working. 😞 I have tried rebooting it and that did not work.
Thanks!
Audra
Moderator edit: label
01-10-2021 11:11
01-10-2021 11:11
Welcome to the Fitbit Community, @Audrairene.
Thanks for the details shared in your post and for already trying to solve the issue. I understand how you are feeling about this situation and recommend doing the following:
For additional troubleshooting instructions, see What factors can affect my heart-rate reading on my Fitbit device?
By the way, I've moved your post to Inspire 2 board so we can keep our forums organized.
Let me know how it goes.
01-22-2021 19:01
01-22-2021 19:01
I received the Inspire 2 for Christmas and now within less than a month, there is no green light. It's not reading my heart rate nor sleep information. I'm rather disappointed since my last Alta HR lasted 3 years. I've tried restarting as well as using rubbing alcohol to clean but it's not working. What else can I try?
01-22-2021 19:25
01-22-2021 19:25
I tried this and it worked😊. I had previously checked the wrist vs. clip setting on my computer and it said wrist so did not expect the setting to be different on the tracker since my tracker automatically sync.
01-22-2021 19:34
01-22-2021 19:34
I tried this and it worked. Thank you @LiliyaFitbit
01-24-2021 12:14 - edited 01-24-2021 12:15
Welcome to the Fitbit Community, @ttse71.
Thank you for joining the thread and sharing that the instructions provided in this thread helped you resolve the issue. I appreciate your efforts and hope you continue enjoying the Fitbit experience.
In case you have some spare time, I would like to invite you to visit our Discussions board where you can make new friends and create new topics.
Keep on visiting the forums. Happy stepping!
05-25-2021 23:33
05-25-2021 23:33
Hi,
are there any other ideas on how to get the green lights back? Iv’e read everything, tried restarting, tried what your post says and still nothing. Everything says the heart rate is on, but it’s gray without the green lights. I just got the Inspire 2 yesterday. Does it take some time to figure out your “routine” or anything?
05-26-2021 20:09
05-26-2021 20:09
Welcome to the Fitbit Community, @CTHawaii.
Thank you for joining the thread and sharing the details of the issue with your device. I understand your concern and appreciate your troubleshooting efforts. Since the issue persists, I recommend getting in touch with our Support team so they can evaluate your tracker's behavior and help you with this matter. Click here to get connected with them via chat or phone.
You can find more information about the Inspire 2 in this manual and in How do I get started with Fitbit Inspire 2?
See you around.
12-02-2021 20:51
12-02-2021 20:51
Hi! I've been having a similar issue with my Inspire 2 that I've had for a week now. I tried holding down the sides of my tracker but it immediately goes to the "water lock" tab, and not to DND. I've also tried rebooting it with no luck. What do you suggest I do?
06-17-2022 07:02
06-17-2022 07:02
Thank you so much!! Precious instructions didn’t mention that holding it for a second or two part. I’ve been trying to troubleshoot for ages. Yay!!
06-17-2022 07:02
06-17-2022 07:02
I meant previous, not precious.
06-17-2022 07:06
06-17-2022 07:06
But what do if your Inspire 2 is completely dead not reacting to any "press and hold" not connecting to charging?
09-09-2022 08:49
09-09-2022 08:49
I followed above instructions. apparently my Inspire 2 was set to 'On Clip". Light is now back on. will know more later if heart rate and sleep are being tracked again.
09-10-2022 06:45
09-10-2022 06:45
As I said I followed the instructions, watch was set on clip now is set on wrist. And my sleep was finally tracked again last night. 5 hours sleep!
09-11-2022 07:09
09-11-2022 07:09
Night 2 did not track sleep. But light still on
09-20-2022 20:51
09-20-2022 20:51
Thank you so much for this! Mine stopped working and I didn't know why. Somehow it was set to clip. I followed your steps and all is well again.
10-25-2022 15:24
10-25-2022 15:24
Thank you for this advice, it really works..
I once experienced in my Inspire-2 that LED is not flashing, hence i didn't get any BPM Rate readings.
It turns out that in the quick setting, underneath the "Screen Wake", my setting is "On Clip" and not "On Wrist"
After i changed it to "On Wrist" then the LED start to flash again
