Change stride length on Inspire 3
There are instructions on doing this under "Exercise Days", but there isn't a menu option for "Advanced Settings". Where can I change my stride lengths?
4 REPLIES 4
Hi @Cheryl_Lynn ! Welcome back to the Community !
I appreciate your message, and I'll be glad to suggest how to add your stride length.
In the Fitbit App, from the Today tab, tap Exercise days.
Tap Menu > Activity settings> Stride Length.
Adjust your stride length.
The full help article can be found here : Can I change my stride length in my Fitbit account?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Correction: I found the Menu and Activity Settings, but don’t see an option to change stride length. Where is this located?
Hi @Cheryl_Lynn ! Thank you for your message and the correction. I really appreciate your feedback, we are going to check what happened.
In the meantime, could you try to make the change through the link Fitbit settings page? scroll down to the Advanced Settings section. Find Stride Length and click Edit. Click Set Your Own and adjust your stride length. Click Submit and sync your device.
That worked too. Thanks for your help!
