04-14-2025
11:46
09:34
LizzyFitbit
04-14-2025
11:46
09:34
LizzyFitbit
Updated this morning and all my goals are gone and I am unable to set goals. When I go and say tap into steps it is blank for today and all previous days, weeks, months and years. Any one know how to fix this?
In the You tab it says something went wrong.
Have logged in and out, done a hard restart, force app closure and turned phone off and on.
11-10-2025 11:37
11-10-2025 11:37
Hello everyone!
I have excellent news. The fix for this bug is available in our iOS 4.56 Fitbit App. Please go to the Apple Store and update your app to this version.
Have a great day!
Best Answer04-14-2025 17:10
04-14-2025 17:10
All fixed - Had to delete app and reinstall now seems to be working ok.
04-17-2025 18:09
04-17-2025 18:09
Did you loose all previous data?
04-17-2025 18:17
04-17-2025 18:17
Nope, everything was there.
Best Answer04-17-2025 19:02
04-17-2025 19:02
I have a same trouble. I tried to connect my inspire 3 to my iPad but it showed same error message.
04-24-2025 08:37
04-24-2025 08:37
My goals went missing with the app indicating something was wrong. Someone helpfully posted delete and reinstall app which restored the goals on the YOU screen but they no longer track on the TODAY screen unless I tap the icon. Any ideas?
04-24-2025 09:42
04-24-2025 09:42
Hi everyone, and welcome to the community forums.
Thank you for providing the details of the steps you've already taken and the screenshots of your app. I'm sorry to hear that you're encountering this issue.
As @LaaLaaLaa suggested, I would also recommend trying to uninstall and then reinstall the Fitbit app. This solution has resolved similar issues for other users. Please try this and then verify if your goals are displaying correctly afterward.
Best Answer04-24-2025 18:26
04-24-2025 18:26
unfortunately, I've tried your suggestion several times but it didn't work.
so I removed app from my iPad.
04-25-2025 09:29
04-25-2025 09:29
Hi there, @c00012.
Thanks for trying the suggestions shared above. Because you mentioned that you removed the app, did you install it back? If not, I suggest trying to reboot your iPad first. After it restarts, please reinstall the app and check if your data then appears correctly on the Today screen and within each of the stat graphs.
04-25-2025
16:16
11:28
AndreaFitbit
04-25-2025
16:16
11:28
AndreaFitbit
absolutely. I did it several times. but nothing has changed. so, I removed app again!
unfortunately, it didn't work. I tried install after rebooting my iPad
several times. but it showed same error message. so, I removed app again!
04-25-2025 17:49
04-25-2025 17:49
The same thing happened to me ..
04-26-2025
10:47
10:46
AndreaFitbit
04-26-2025
10:47
10:46
AndreaFitbit
Inspire 3. I have the same problems. It started maybe 3 or 4 days ago. My exercise days changed from 6 to 5; there is no way to change it or any other goals. All of my previous weeks now have 5 exercise days which throws other data points off.
I could not sync with my phone unless I updated my Bluetooth connection, which I think is very weird. I also started Fitbit premium I don’t know if there is a connection there.
I’m not very confident if I uninstall and reinstall the app my history will not be lost. Is there a way to back up my data? any help would be great, I really liked my Fitbit until now
thanks!
I just noticed my active Zone Minutes changed to 0, I have a gray box for steps, hourly activity, can see nothing when I click on distance, steps, energy burned…
11-10-2025 11:37
11-10-2025 11:37
Hello everyone!
Have a great day!
