08-31-2023 13:13
08-31-2023 13:13
My Inspire 3 is no longer syncing as it should to my iPhone. I have the latest update, have searched help guide and user forums, and tried the “this should fix it” with no success. I have been a FitBit user for years and years and cannot understand why this is now happening. Is (or has) anyone else experienced this?
08-31-2023 14:28
08-31-2023 14:28
My inspire 3 stopped syncing on 8/29/23-contacted chat-and did all the steps-IOS up to date-Fitbit app up to date-logged out of the app-deleted the app/reinstalled it-rebooted my iPhone and still nothing. Could not log back in. Called Fitbit help-told me try in 24 hours. Couldn’t log in to the Fitbit app on 8/30-after 24 hours-and called Fitbit again-but had tried to log on with MacBook Air in the meantime-got a server error-try again later. Also tried different browser-Chrome -still server error. The Fitbit app just spins. The Fitbit assistant said she was sending the problem to another team and I should expect an email from them in the next 48 hours. They assured me that all data would be retained. I was able to sign on and pair my inspire 3 this afternoon on Verizon LTE-just giving me todays data stats -none of the previous day data is there and still getting server error when logging in on my Mac Air. Will not sync now. Will call Fitbit help again tomorrow-after 48 hrs is up w/no contact from them on resolution of the problem. You are not alone😜
09-01-2023 05:22
09-01-2023 05:22
Best Answer09-01-2023 11:55
09-01-2023 11:55
I am having exactly the same as you.
Best Answer09-01-2023 12:33
09-01-2023 12:33
Best Answer09-02-2023 07:26
09-02-2023 07:26
I had this problem yesterday and today. Just noticed my iPhone iOS updated to 16.6 and I still had a Fitbit app update available. Just updated the Fitbit app to v3.89 and now it syncs! See if you have an app update. Haven’t done a firmware update yet.
Best Answer09-02-2023 07:33
09-02-2023 07:33
Best Answer09-04-2023 03:32
09-04-2023 03:32
I’m on iOS 16.6 and the latest Fitbit app, but my Fitbit stopped syncing on 31st August. Nothing I’ve done reinstates the sync.
Best Answer09-23-2023 00:27
09-23-2023 00:27
I have been having the same issue (started 9/18/2023). JUST now, I saw Fitbit put out an update w/in the last 24 hours (version 4.00).
My iPhone has update 16.6.1.
AFTER the new Fitbit update, my Inspire 3 FINALLY synced! I HAVE to assume it’s the Fitbit update. I had tried many times and many fixes, including staying up the last two hours tonight. The ONLY time it I had success was with the latest update.
~ I’ve owned Fitbits for ten years & unfortunately the biggest downside is getting help from Fitbit directly. Point being, I have dealt with product frustration before. I’m thrilled something finally solved an issue! Thank you all for your posts, they helped fix the issue!!
Hoping this helps for others!!!
