Hello Fitbit support,
My fitbit display is blank. The following are steps I tried in the same order
1. I tried to force restart - did not work
2. Upon your advice I restarted fitbit connecting it to the charger - did not work
3. Tried to change my clock face
4. Also upon your advice I let the fotbit run out of charge, then connected to the charger and force restarted. - This worked for about 24 hours and then it's back to blank screen.
5. Tried force restarting and now that does not work either.
What do you think I might be missing? Looking forward to hearing from you.
Thanks!!
@Saran08 , A warm welcome to the Community! Thank you for your message and efforts.
You have already tried everything that we can suggest here in the Community! In this case if you haven't done so yet contact our Support team .
They'll be more than glad to assist you further.
Tap here to get connected with Support.
Fill up the form, you'll get some articles recommended.
Then you'll see the options to contact Support.
