10-22-2024 13:20
10-31-2024 08:23
10-31-2024 08:23
I've got the same issues. If someone could post the steps to roll back to a working version of the app (4.27), that would be great. 4.28.2 doesn't work on either of my Android devices.
10-31-2024 09:16
10-31-2024 09:16
I managed to install v27 from A...mirror and my tracker is now syncing again. I have switched off autoupdates. Don't know why fitbit can't provide a rollback to v27. Surely they have backups?
Best Answer10-31-2024 09:43
10-31-2024 09:43
Did you have to uninstall the app first? Did you lose your data?
Best Answer10-31-2024 09:54
10-31-2024 09:54
Fitbit won't provide a rollback to v27 as it's only affecting a subset of mobile devices. I have downloaded v27 from a mirror site and now got mine working. Be cautious about doing this unless you are sure you know what you are doing.
Best Answer10-31-2024 12:12
10-31-2024 12:12
10-31-2024 12:49
10-31-2024 12:49
Thanks Irish6612. If it doesn’t work I'm going to try to get my money back. The standard of free step apps has much improved since I last looked.
Best Answer10-31-2024 13:32
10-31-2024 13:32
Best Answer10-31-2024 13:48
10-31-2024 13:48
Best Answer10-31-2024 17:15
10-31-2024 17:15
May I ask what mobile devices are being affected? I have a Samsung Android OS 12 if that helps. I do not have an I phone. My app was updated this morning but I have not yet tried to sync my fitbit and re-setup my device. I did not look to see which version of Fitbit was installed but other posts here indicate that v28.2 still does not fix the problem. Thanks!
Best Answer10-31-2024 18:02
10-31-2024 18:02
Best Answer10-31-2024 18:23
10-31-2024 18:23
Best Answer10-31-2024 23:33
10-31-2024 23:33
My Inspife 3 hasn't been working for over a week now. Won't sinc and have tried all suggestions. I also have samsung A13
Best Answer11-01-2024 12:22
11-01-2024 12:22
Just installed latest update of 4.28.3 but it still won't sync! I'm going to contact support again.
Best Answer11-01-2024 12:27
11-01-2024 12:27
Best Answer11-01-2024 12:36
11-01-2024 12:36
Best Answer11-01-2024 14:47
11-01-2024 14:47
Best Answer11-01-2024 19:16
11-01-2024 19:16
I just downloaded and installed 4.28.3. Once it was installed, I opened the app. My steps (about half of them) for today updated almost immediately. I pulled down from the "today" screen, and it seemed to take forever. I thought it was failing and walked away from my phone, busy with something else. I came back and tried again. It worked! I didn't have to uninstall and reinstall, or reboot, or anything. I hope you all have the same happy result!
11-01-2024 19:18
11-01-2024 19:18
When you get it, install 4.28.3. Mine works now.
11-01-2024 19:47
11-01-2024 19:47
11-02-2024 02:55
11-02-2024 02:55
Mine works too. But please Fitbit, you could have talked to us. Be inspiring!
