03-28-2023 22:19
03-28-2023 22:19
Hi,
Is there a way to manually log mindfulness session? I like to do meditations without a guide in the Fitbit app. I can't find a way to log meditation if I don't use app's guided audio.
Thank you
03-30-2023
11:56
10:18
03-30-2023
11:56
10:18
@goranm , Thank you for your message and feedback. Nice to see you around.
At this time there is no possibility to log a mindfulness session manually.
I found this product feedback : Able to manually log mindful sessions in Mindfulness tile
Have a look at it, and if you want to support it, leave your comment and vote for it.
04-05-2023 16:36
04-05-2023 16:36
I log my meditations in the exercise section, as that’s one of the exercises already on the Fitbit app. However it doesn’t add it to the mindfulness tile which is disappointing.
04-06-2023 14:34
04-06-2023 14:34
Yes, you can manually log your mindfulness or meditation sessions in the Fitbit app. To do this, follow these steps:
Once you have logged the session, it will appear in your exercise history, and you can view it within the Fitbit app. Note that manually logging a session like this will not provide the same level of detail as a guided meditation in the app, but it will allow you to keep a record of your mindfulness practice.
Keep in mind that these instructions are based on the Fitbit app's interface as of my knowledge cutoff date in September 2021. There may have been updates or changes to the app since then, but the overall process should be similar.
