05-22-2019
09:39
07:16
AlejandraFitbit
05-22-2019
09:39
07:16
AlejandraFitbit
The notification vibration is so weak on my New Inspire HR that it is worthless for that. Can Vibrations be made a stronger signal? Maybe Fitbit even do a software update. The cheaper Fitbit have stronger signals.
07:24
13:18
05-23-2019
07:24
13:18
It's great to see you around @Jndrva.
If your Inspire HR vibration is too weak, I recommend restarting the unit by following the instructions provided in the help article: How do I restart my Fitbit device?.
Let me know the outcome.
Best Answer05-31-2019 09:54
05-31-2019 09:54
Restarting did not help it. It gets notifications but unless I have my hand up and happen to see it light up, I would never know. I don’t even realize I have passed my goal until I see it on my phone. I had a flex 2 before, which cost much less, so I know how it should feel on the wrist when it vibrates. This past week I have seen many complaints about Inspire HR faint vibrations on online review comments, so something Fitbit needs to address and let us know or do an update. Otherwise I like it, but this is annoying. Thanks.
05-31-2019 09:55
05-31-2019 09:55
@AlejandraFitbit wrote:It's great to see you around @Jndrva.
05-31-2019 11:36
05-31-2019 11:36
I have the same issue. I used to rely on my Alta HR as my personal alarm in the morning, but so far after owning the Inspire HR for five days, I've managed to sleep through three out of five wake up alarms. It's a real bummer because it's such a useful feature to avoid having your partner wake up when you have to get up.
Any change fitbit might consider adding an option similar to that of the Charge 3 to increase vibration intensity?
06-28-2019 16:04
06-28-2019 16:04
Same problem here and it's driving me mad! I love this thing, I just wish I could feel it love me back! There has to be something you can do via an update that can solve this issue.
08-11-2019 13:32
08-11-2019 13:32
I’m having the same problem with the weak vibration. Ready to return it and go back to my old cheaper flex2. Come on Fitbit....fix this problem!
09-12-2019 13:03
09-12-2019 13:03
I have the EXACT same issue. My Fitbit ONE would wake me up every single time. Inspre HR allows me to sleep right through the alarm. Everything else is wonderful. A software update should fix this. I have a friend that just got a new Inspire HR and upgraded from a Flex2. She has the same problem. We are both considering using our old Fitbits for sleeping and our Inspire HR for daytime use. That really defeats the purpose.
Thank you!!!
07-28-2020 08:48
07-28-2020 08:48
My Inspire HR vibration is so weak, I can't always feel it. Even while I'm watching it reach my alarm time!! I wish there was a way for me (or Fitbit) to adjust the vibration strength.
