Setup error
ANSWERED
I've just got the Fitbit and am frustrated already.
The link to the set up gave me       https://www.fitbit.com/en-ca/404
I tried using iMac and laptop
Wonderful start to using this tool
32 REPLIES 32
The windows setup link is still dead. I'm also in Canada, and I get a 404.
This has been broken for 3(?) months.  Is there a plan to do something about it?
Welcome to the Fitbit Community, @slackerjack1943.
Thank you for joining the thread and confirming that the issue persists. I appreciate the additional details and would like to confirm that our team was informed about this and we're actively working in order to have a solution released soon. Thank you for your patience. Meanwhile, I suggest to use a workaround to use another link for setup: https://www.fitbit.com/au/setup
Let me know if you have any questions.
Sorry, I am no longer involved as I sent it back.
There is an older message that suggests other methods including going to an
Australian web page.
Good Luck!
It's nice to see you around, @jmb1111
Thank you for your participation in the Forums. I appreciate your time and efforts to help other users.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members.
Looking forward to seeing you around the forums.
And it's still not working as of May 5, 2020...
Truly amazing - is Canada so irrelevant?
I am having the same issue. It keeps giving me unavailable for setup. Following a diff trail. Not sure what to do with that. Can anyone help?
Use the australian setup link:
For some reason the canadian one is broken and nobody IN THE ENTIRE COMPANY is interested in fixing it.
I really want fitbit to succeed as a company, but the failure to address something as simple as this is a terrible look.
Is there a fix/update for the 404 error for users in Canada?
This is the second Charge 4 that I have purchased believing that the issue was the device itself however I believe it is based on my location. I am in the process of returning yet another product and choosing not to purchase any other fitbit devices.
Can anyone help me?
Thank you for the tip! I tried it and it worked. Pretty sad I could not do it on the Canadian link, and had to go to an Australian link to get Fitbit/setup.
Thanks again, you were a lifesaver
You are welcome - I got it from another person on the board.
I decided to return the Fitbit - I figured any company that could/would not
fix a problem such as this does not deserve my business.
Good luck and stay fit! 🙂
Still broken for all Canadians. 5 months later. Probably even longer. Copy pasted response every time. Sad.
Make sure you have the following:
Charge the 4 charging cables that came in the box with your device.
UL-certified wall charger. Note: Don’t plug the charging cable into a computer or USB hub for these troubleshooting steps.
Before getting started, make sure your device is connected securely to the charging cable:
Clip the end of the charging cable to the port on the back of Charge 4.
Make sure the pins on the charging clip lock securely with the gold contacts on the back of the tracker.
Make sure the device is centered in the charging cable and that the button on the side of Charge 4 is visible through the side of the clip.
When the connection is secure, Charge 4 vibrates, and a battery icon appears on the screen. Note: You may have to adjust the tracker to the correct position in the charging cable.
Hope You Find This Useful,
Peter
