10-02-2018 09:13
10-02-2018 09:13
10-02-2018 10:50
10-02-2018 10:50
Welcome to the forums!
There is something wrong with it. So please contact support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Hope to see you around the forums! Join in on the discussions forums!
Wendy | CA | Moto G6 Android
10-02-2018 12:06
10-02-2018 12:06
@Banana123 since your posting in the Ionic board, and not a board for one of the Fitbit Charge versions, I'm going to assume the charger your reffering to is the third party device you plug into the wall.
This buzz could mean one of several things.
- The wall unit is not able to handle the power the Ionic wants.
-The wall unit might be about to quit on you.
- You are young enough that you can still here the normal high pitch of the local oscillator in the digital power supply in the wall unit. If this is the case, then nothing is wrong.
Is the wall unit or the ionic getting exceptionally warm while charging?
My thought would be to try a different wall unit, like mane the one used to charge a phone.
If both wall unit give off a buzz, then you might want to contact Fitbit as @WendyB has advised.
My thought would be if the wall unit is simply getting slightly warm, there is no problem.
The ionic should not be getting warm, if it does, then unplug and contact fitbit.
