03-11-2018 19:50
03-11-2018 19:50
Received the Fitbit Ionic for Christmas 2017, had the surge and wanted to upgrade. I have had consistent syncing problems with my Android Phone. Then the Firmware update happened and it wouldn't work at all. We tried everything I finally got frustrated and did a factory reset on the Ionic and now it won't do anything at all. It just keeps trying to go through the set up but won't make it past the WiFi set it just can't connect. I've wasted so much time trying to get this to work. I loved my surge but my band kept becoming detached and I liked the ionic options. Did I just get a bad watch? HELP so frustrated and don't know what I can do. It's only a few months old..
Kristine
02-10-2020 14:20
02-10-2020 14:20
This answer has nothing to do with the issue we are having.
Best Answer02-10-2020 14:51
02-10-2020 14:51
Best Answer02-10-2020 15:39
02-10-2020 15:39
Just to clarify what happened and all the routes i've tried. My Fitbit Ionic is 1 year and 5 months old. Today my watch was working fine at 3:05 PM with 50% battery life left. I was having syncing issues and also wanted to reset my data to start fresh, so I ran the factory reset procedure, which is this (WARNING: This may ruin your device): "1. Remove the Ionic from your account. 2. Delete the bluetooth pairing. 3. Press and hold all buttons on the device. 4. Wait until the Fitbit logo disappears, then release the bottom right button. 5. Wait until you feel a vibration, then release the other buttons. 6. You will probably see a red X message, just ignore that and setup the device again." I did that, felt the vibration, then released the other button. Never got the message. The device HAS NOT came back on since! I've contacted customer support and we exhausted all support options (I.E. hold all buttons down, hold the left button and the bottom right button down, tried running the factory reset again (even with the device dead)). Customer support did a good job and all they could, but it makes me wonder if this is a known issue for this watch from the Dev team? The device dying after a factory reset? I was looking forward to the Ionic 2, but this doesn't give me much confidence in this line of product. I also don't like the syncing issues and would like to see the ability to sync through usb to a computer. *BTW, the "Best Answer" to this question thread has nothing to do with the issue.
02-12-2020 17:27
02-12-2020 17:27
Best Answer02-20-2020 11:15 - edited 02-20-2020 11:26
There might be a glimmer of hope on this problem. Okay, I've got the screen to come back on with a zero percent battery showing. This is a factory reset issue just to reiterate. Hold down the usual buttons and start tapping on the touchscreen. It does seems to respond. Perhaps factor y reset kills the battery? Idk, still occasionally working on a solution
Best Answer02-20-2020 11:32 - edited 02-20-2020 11:41
I mean, if that's the case, battery replacements wouldnt be that expensive and give confidence for the Ionic 2 when it comes out for a company that would go out of it's way to help out customers and solve a glaring issue. Logistically i idk but just a thought
Really liked my Ionic when it worked right and the badges.
Best Answer02-22-2020 10:20
02-22-2020 10:20
Same issue.
The moment to change brand has come!
Goodbye Fitbit.
02-29-2020 12:44
02-29-2020 12:44
I did the factory reset and it will not turn on. I've had it for only a year and 3 months. Nothing but a paper weight now.
