11-14-2017 16:01
11-14-2017 16:01
I am having trouble signing in to the Fitbit Coach app it says that my email is already associated with another account does anybody know what is causing this issue. I am trying to sign in using my fitbit account if that helps
Best Answer11-14-2017 16:27
11-14-2017 16:27
@MikeyJG wrote:I am having trouble signing in to the Fitbit Coach app it says that my email is already associated with another account does anybody know what is causing this issue. I am trying to sign in using my fitbit account if that helps
Hi @MikeyJG,
Is it possible you used that email address to sign up for FitStar at some point? Either way, you'd want to contact Fitbit Support, so they can sort it out for you.
Best Answer11-14-2017 17:12
11-14-2017 17:12
I believe I used that email for fit star I thought it wouldn't make a difference since coach is the new FitStar
if I'm not mistaken
Best Answer11-14-2017 18:08
