Hi,
I have a Fitbit Ionic and after some time without using it, I am not able to turn it on. He's been charging for 10 hours but I can't turn it on. I've tried to press the buttons to restart but it doesn't work. Can you tell me what I can do more? thank you.
Best AnswerMy Fitbit ionic has also just died have tried cleaning the connection and a different charging cable but no joy
Best AnswerHi just solved my issue
hold down all three buttons untill fitbit icon came on- must have turned itself off when battery low 5%- it then started charging - all good now
