02-23-2018 20:36
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-23-2018 20:36
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Not sure as to root cause. Ionic and iPhone (apps and iOS) updated. iPhone and Fitbit app connect/find Ionic but app won’t sync. Followed troubleshooting steps, no resolution.
Accepted Solutions
02-26-2018 08:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-26-2018 08:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
- Who Voted for this post?
Ultimately, I solved the problem through removing the device from my Fitbit
app, forgetting it via the iOS Bluetooth, resetting the ionic device
(through the two side button press and hold) and then starting the sync
process from scratch as if a new device.
02-26-2018 07:16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-26-2018 07:16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Welcome to the Community @DavosBravosi. I appreciate the troubleshooting you've followed. In this case, I would like you to make sure you have a supported device and that you've properly performed the syncing steps provided here.
Hope this helps! Keep me posted.
02-26-2018 08:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
02-26-2018 08:51
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
03-01-2018 11:54
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
03-01-2018 11:54
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Thanks for sharing the troubleshoot that resolved the syncing issue @DavosBravosi. Hope you can continue enjoying your Ionic.
04-04-2018 06:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
04-04-2018 06:15
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
I have solved the Not sync problem on my Fitbit Ionic by changing from wifi (turning off wifi) to receiving data directly from my mobile company. En español desactive el wifi y empece a recibir datos de mi provedor de datos y voz. en este caso en mi país la compañía Movistar.
05-11-2018 21:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-11-2018 21:12
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
My Fitbit Ionic tracker syncs with my "PC's Google Chrome connection to my Fitbit.com homepage" if "my PC's Fitbit.com home page is open" and "nearby I have opened & recently refreshed the Fitbit app that I downloaded on my Android phone." Also, I have found that if I do not have my Android cell phone available nearby, I can still sync with my PC's Fitbitcom homepage by attaching the charging wire to my Fitbit Ionic tracker so I can read the charging percentage (and then detaching the charging wire) while I am near to my PC that is running Google Chrome while connected to and open at my Fitbit.com homepage.
05-15-2018 17:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
05-15-2018 17:06
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
It's great to have you here @WaltIonic! Thanks for the details that you've mentioned. I appreciate that you've shared the ways that you can sync your Ionic to your Fitbit account, just as you mentioned, you can sync your tracker using the charging cradle and if you have all day sync, your Ionic will sync anytime you're nearby.
If you want to learn more about it check How do Fitbit devices sync their data?.
