03-30-2018 19:17
03-30-2018 19:17
My Ionic GPS stops tracking at 1km. This has started happening since I upgraded the OS on Tuesday night. (on average, it happens every second day).
I have contacted Fitbit and they said they are aware of the bug. Does anyone know how to downgrade the OS (go back to what was previously installed)? I am a runner and use Strava and this is really frustrating.
Thanks in advance
Best Answer04-02-2018 08:05
04-02-2018 08:05
@Celeste14 Welcome to the Fitbit Community! Thanks for reporting this here on the Fitbit Community and for contacting customer support regarding this.
It is not possible to downgrade to a previous firmware version on Ionic or any other Fitbit device.
Fitbit is currently investigating this, your feedback is very valuable. I will share updates from the team when I hear them.
In the meanwhile, please let me know if the GPS map you get when you finish the activity is correct? Check if the map is showing correctly and the distance too low.
Keep me posted!
04-02-2018 13:58
04-02-2018 13:58
I have had this happen multiple times as well. Both before AND after the upate. It reset itself 4km into a 30km race. I...was....PISSED
04-02-2018 16:03
04-02-2018 16:03
Hi,
Thank you for your reply, the map is showing as correct and the distance is correct as far as the Ionic is concerned (the Iconic has always been short).
Thanks,
Celeste
Best Answer04-02-2018 19:11
04-02-2018 19:11
oh man.
i better stop using ionic for my next race.
Best Answer04-25-2018 00:14
04-25-2018 00:14
I am getting the same issue - every time I go running my Ionic buzzes after 1km and it goes back to watch screen and the tracking has stopped ; Othen have to start again and the second time it seems to keep tracking
Best Answer04-25-2018 00:59
04-25-2018 00:59
Hi,
Since Fitbit won't assist with a workaround I have found a temp solution. If you turn the automatic lap setting off (under exercise/settings (cog in LH corner) /show laps) this stops the watch from vibrating every km and has since worked (5 day i a row) without stopping the watch.
I hope this helps you as well.
04-25-2018
15:00
09:59
04-25-2018
15:00
09:59
@Rachel1985 @jettyp72 Welcome to the Fitbit family! Thanks for reporting this situation with GPS tracking on Ionic.
Our team has received the feedback from everyone in this thread and is working to investigate these reports further. I will share updates from the team when I hear them. Thanks to everyone for your reports and understanding. @dorst622
In the meanwhile, please try the great workaround shared by @Celeste14 which seems to be temporarily fixing this problem. Please confirm if this works for you as well.
I will keep you posted! ![]()
05-05-2018 06:29
05-05-2018 06:29
Are there any updates on this fix? My watch still having this problem. Thanks
Best Answer05-05-2018 08:27
05-05-2018 08:27
my ionic longer have this issue. did 3 gps run after applying the workaround.
now i only have issue where the gps distance is out by >10%
Best Answer05-06-2018 03:25
05-06-2018 03:25
I am having some issues with my Ionic. When out running the tracker keeps stopping by itself. The fitbit logo flashes up and then it simply goes back to the home page. I then have to restart. This is so frustrating when tracking my runs. I have spoken with twice now and all that has been suggested is a factory reset or turn off the smart track. I have used this for 4 months and have only noticed these issues in the last 2-3 weeks. My friend who runs with me is still using his surge and he has no issues whatsoever. Fitbit also suggested that it may be the GPS and weather affecting the signal but it was a very sunny day with no cloud coverage. Has anyone else had similar issues?? Any help would be great. Thanks
Best Answer05-20-2018 09:59 - edited 05-20-2018 10:00
Mine stopped tracking after 1km today as well as on my run yesterday morning - also after exactly 1km. Updated the OS late last week 😞
Best Answer06-01-2018 23:40
06-01-2018 23:40
This happened to me again - and during my first South African time trial. 1.01k and then nothing. No GPS, no Strava, which is frustrating.
Running my first ultra next weekend and not sure if my Ionic with work. After all get issues I've had with the tracker, I'm become disillusioned that it isn't fit for the purpose I bought it: tracking runs, rides swims reliably.
Best Answer06-01-2018 23:41
06-01-2018 23:41
Has anyone contacted Fitbit support about this? It's been at least a few weeks with this problem now.
Best Answer06-02-2018 00:26
06-02-2018 00:26
Best Answer10-30-2018 14:17
10-30-2018 14:17
Do not buy this watch. Known issue on going for ages. Watch cannot record your times, it stops on 1km. Fitbit haven't fixed it and keep selling this watch. Make sure you read this.
10-30-2018 14:33
10-30-2018 14:33
So this is on going for over 6 months. Way to go fitbit....but hey carry on selling them. How many Xmas presents are goig to be bought, with fitbit knowing they don't work?
Best Answer10-30-2018 14:52 - edited 10-30-2018 14:53
It is not only GPS based workouts but any other, too. It's well known and well ingored issue of crashing Exercise app. To me, it happened many time during Run, Cycle, Workout and if I used any other type of workout it would happen, too. On crash there is a short vibration. I guess it is specific for the OS. There is no workaround. I don't use any cues, any laps, anything. All I do is just hitting recording and that's it. I lost part of my workout last Monday. It is the most critical issue and it doesn't seem to be addressed.
Best Answer02-18-2019 07:58
02-18-2019 07:58
Hi - I am experiencing this issue regularly as well. Please can you confirm if a fix has been established?
Thanks, Tim
Best Answer02-18-2019 08:33
02-18-2019 08:33
