10-30-2017 22:20
10-30-2017 22:20
I forgot to put my PIN in my Iconic when I put it on. My niece was playing with my watch then I noticed it said " unlock with phone". I have tried everything but still can't unlock it.
10-31-2017 00:56
10-31-2017 00:56
I found another thread with this issue. Have you tried the suggestion in this?
https://community.fitbit.com/t5/Ionic/Watch-says-unlock-with-your-phone/m-p/2240897
10-31-2017 01:01
10-31-2017 01:01
I have tried that. It just keeps coming up with an error.
10-31-2017 02:05
10-31-2017 02:05
Not sure what “tried everything” encompasses but to try and gain some more information, have you set up FitPay yet? If not, the pin lock is an optional setting that can be turned off in the phone app.
10-31-2017 04:08
10-31-2017 04:08
I have fitbit pay and have tried to change the pin
10-31-2017 04:26
10-31-2017 04:26
In the Fitbit app go to Ionic icon and scroll to the bottom where it says device lock and tap it. It will say some stuff about a factory reset, do this and you should be fine.
I had the joy of doing it last week.
11-03-2017 15:19
11-03-2017 15:19
@Drew_Watkinson wrote:In the Fitbit app go to Ionic icon and scroll to the bottom where it says device lock and tap it. It will say some stuff about a factory reset, do this and you should be fine.
Hi there @Drew_Watkinson!
I found a previous post by you and I just found this one, I'd shared in the other post a possible solution in case that should happen again.
https://community.fitbit.com/t5/Ionic/Unlock-from-phone/m-p/2268033#M11310
