09-30-2017
05:57
09:17
09-30-2017
05:57
09:17
Hey Pals,
is there a way to re calibrate the Ionic?
I was in my car when it said to lay it on a flat surface, but i was not able to in the car...
07-20-2018 10:01
07-20-2018 10:01
Same issue here. While I love the Ionic, it undercounts the steps. My One is much more accurate.
Best Answer08-10-2018 18:25
08-10-2018 18:25
How or when about if in fact fitbit will ever think about doing an xl wrist band.
Best Answer08-11-2018 11:49
08-11-2018 11:49
I think sfringers tip is a possible solution for all guys who have this calibrating problem every day.
But listen Fitbit, it is for sure not much work to integrate an "calibration" option under settings.
Best Answer11-14-2018 13:35
11-14-2018 13:35
My ftibit does not seem to be counting my steps accurately. A friend and I walk together, same stride and she has more steps then I do. I would like to calibrate it my fitbit Iconic, but I don't know how to make it calibrate. I have had it tell me to calibrate before, but how do I initialize it. Thanks!
Best Answer12-26-2018 13:56
12-26-2018 13:56
Same Question than Sunset, if i Miss calibration how i trigger when im able.
Best Answer01-12-2019 17:49
01-12-2019 17:49
Having problems calibrating my Iconic. Have tried since Christmas and even rest it to factory settings and let it run for a hour to upgrade everything. Anyone know how to resolve this?
Best Answer01-16-2019 11:09
01-16-2019 11:09
I plug my ionic in but so t calibrate
Best Answer02-16-2019 13:58
02-16-2019 13:58
Help me with this. I got mine yesterday. But it has never detected my hr. It always fails to do the calibration. It does not matter if is facing down side or in the air. It fails. Always
Best Answer02-18-2019 08:31
02-18-2019 08:31
Best Answer10-15-2019 11:18
10-15-2019 11:18
If I was away and not able to calibrate when watch asked me to do so, how can I initiate it to do it now that I'm able to plug it in.
Thanks
Jeremiah
10-15-2019 12:05
10-15-2019 12:05
Best Answer11-23-2019 19:47
11-23-2019 19:47
I agree with Sunsetrunner.
while I get the pop up to calibrate or to “snooze” it for later. It would be great to calibrate it manually by either putting the option in the settings or leave it as a message. (Scroll down and reclaim the once snoozed action)
Best Answer05-18-2020 02:48
05-18-2020 02:48
Hi there.
There is a way to force calibrate your ionic. This is only if you really onte to calibrate your ionic.
You either wait for an update to occur or reset your fitbit.
Remember this is only if you know you really need to calibrate your ionic.
Enjoy!
Best Answer06-06-2020 05:10
06-06-2020 05:10
Is there a way to recalibrate the Fitbit? I recalibrated mine a few weeks ago and it has been on average a tenth of a mile off on my runs.
Best Answer09-06-2020 08:27
09-06-2020 08:27
The GPS seems inaccurate is there a way to calibrate?
09-09-2020 06:30
09-09-2020 06:30
Is there a way to calibrate my Ionic fitbit manually?
Best Answer09-07-2021 18:15
09-07-2021 18:15
I did this and it vibrated but just keeps asking me to calibrate over and over again.
Best Answer09-08-2021 15:46
09-08-2021 15:46
Welcome to the Fitbit Community, @Tinychef.
Thank you for joining the thread and sharing the details of the issue you're experiencing. I would like to confirm if you've tried the following:
Hope this helps.
