06-05-2018 01:31
06-05-2018 01:31
Hi, my iconic won't turn on even after the recommended pressing the back (left) and bottom (right) buttons for around 10 secs. Anyone have this problem?
06-05-2018 01:39
06-05-2018 01:39
since yesterday i have the same problem 😞
Best Answer06-08-2018 05:28
06-08-2018 05:28
Mine won't turn on either since yesterday. I am not sure if it will not take a charge or what?
I have tried restarting it, cleaning it, checking the plug in port with other usb cords, nothing is working.
06-08-2018 07:42
06-08-2018 07:42
Good luck with this, I had the same issue. I am 18 days into the warranty replacement process with no end in sight...
06-08-2018 10:27
06-08-2018 10:27
Yes, I am having the same problem. My first Ionic worked great for about two weeks then went dark and never came back. I exchanged it at the store and now, about two weeks later this one has gone dark also. Wondering if this an ongoing issue? or is there a way to restart them?
06-08-2018 11:52
06-08-2018 11:52
When you call in or use the chat they make you feel like you don't know how to use your device and say this is the first time that they have heard of this happening. There is something to be said for honesty, say it is an issue with the current OS and are working to fix it, but at least acknowledge that it may not be user error. (Seems strange that this many users would be producing the same error.)
06-09-2018 22:36
06-09-2018 22:36
Mine tooo just stopped working. Will not wake up - just a blank screen. Tried all the reset techniques offered in the forum.
Best Answer06-22-2019 05:33
06-22-2019 05:33
Same thing with mine ..about 2 weeks ago purchased it from best buy. Nothing seems to restart with reccomended steps...is it worth keeping?
Best Answer06-22-2019 11:49
06-22-2019 11:49
Yup, good luck getting it replaced. They'll place the blame on you and refuse to replace it. Because it's some how your fault, not their devices are faulty. They'll use any excuse too and beat around the bush.
Best Answer06-22-2019 14:43
06-22-2019 14:43
Best Answer06-22-2019 19:00
06-22-2019 19:00
Same thing happened to me today.........i'm going to give it some time and hope i can get it to turn on in the morning
Best Answer06-22-2019 19:14
06-22-2019 19:14
I could not get any type of warranty.
Best Answer06-22-2019 19:16
06-22-2019 19:16
"I hope you have success.
