09-29-2017 17:59
09-29-2017 17:59
I have the Blaze and use for bicyling connected to my Iphone for GPS. My big complaint is that when I stop, I sometimes forget to pause and then restart. Other Apps, like Mapmyride, stop automatically and then restart when you are riding. Will the Ionic have this feature??? Its important.
Thanks in advance for any assistance...
Best Answer10-01-2017 18:33
10-01-2017 18:33
@Skipfit wrote:Thanks.!!!! I don't use earbuds for safety as well. Just my Iphone on a cradle... works perfect. Good to know the GPS auto pause works as advertised and is reasonably accurate. I use mapmyride on the Iphone and it matches very accurately my Blaze (if I remember to renew when manually pausing while on a quick rest). I probably am going to go for the Ionic... Any other thoughts (pros/cons) you might have would be appreciated as well. Thanks so much.
I think it is pretty much like you hear. If you want a good workout tracker Fitbit is it. If you are looking for a smart watch that tracks your workouts then you should get something different.
That being said the ionic is a great device and is only going to get better when they work out the bugs with the new OS. So far the workout tracking is spot on for me but I mostly ride a bike and walk. I add a little weight training in when I can. The weather app and NFC payments are going to be just about all I need when they are working as intended. The weather works but some issues syncing and NFC payments not released yet.
I'm very upbeat at this point with the potential of the Ionic. We will see what FItbit does. I hope they step it up and really puch the new OS and get a ton of different apps for it. But for me it does what it should and it does it well. Everything else is icing on the cake.
Best Answer09-29-2017 18:49
09-29-2017 18:49
Ionic has an "auto pause" feature. I have not tested it yet, but it's there on my Ionic
Best Answer09-30-2017 11:07
09-30-2017 11:07
I tested the auto pause yesterday while running outside and it worked perfectly!
Best Answer09-30-2017 11:31
09-30-2017 11:31
Best Answer09-30-2017 11:35
09-30-2017 11:35
@Skipfit Sunrise Girl used it for running. You'll want someone to verify on cycling because the Blaze supported auto-pause for running but not for cycling.
09-30-2017 11:52
09-30-2017 11:52
Best Answer09-30-2017 11:58
09-30-2017 11:58
@bbarrera I had no idea the blaze supported that!! Where is the setting for that on the Blaze??!?
Best Answer09-30-2017 12:12
09-30-2017 12:12
Best Answer09-30-2017 13:08
09-30-2017 13:08
@Skipfit. I tested it with running and it worked perfectly. I ran and then stopped and started a few times....worked with no issues. I have not personally tried with cycling but it is supposed to work for that as well
09-30-2017 22:38
09-30-2017 22:38
@SunriseGirl wrote:@bbarrera I had no idea the blaze supported that!! Where is the setting for that on the Blaze??!?
sorry I don't run, and a triathlon friend insisted the Blaze auto-pauses for runs. She was wrong.
Best Answer10-01-2017 08:37
10-01-2017 08:37
@bbarrera No problem!
10-01-2017 10:42
10-01-2017 10:42
Did my first bike ride with the ionic today. short 16 mile 1hour ride and the GPS worked great. The auto pause worked just as it should when I stopped at a light. The distance and speed is pretty accurate. I'll see how it goes over the next few weeks.
10-01-2017 11:47
10-01-2017 11:47
Cycling is my favorite activity. Having auto pause for cycling, on board music, and GPS... on my wrist! Can’t wait for the ionic to show up tomorrow!!!
10-01-2017 12:29
10-01-2017 12:29
Reggie,
Thanks so much for letting me know you are a bicyclist and getting the Ionic... Let me know what you think about it - particularly how the auto-pause works....
Skip
Best Answer10-01-2017 15:09
10-01-2017 15:09
Everything worked like you would expect for my bike ride today. I had the GPS on and music streaming to speakers I have mounted to my bike. I dont like having ear buds in because I can't hear anything around me. Any way I started the ride with the Ionic at 88% battery and had GPS and music going the whole ride about 1:30 mins including pauses and had 68% left on the Ionic when I finished. Just to give you and idea of the battery.
10-01-2017 15:16
10-01-2017 15:16
10-01-2017 18:33
Best Answer10-04-2017 12:08
10-04-2017 12:08
Curious as to whether you get steps for cycling. I know some people don't want to, but I do. My Charge HR did, but my Blaze doesn't. Thanks.
Best Answer10-04-2017 12:12
10-04-2017 12:12
Best Answer10-04-2017 12:24
10-04-2017 12:24
I thought the algorithm on the Charge HR was reasonable: 10,000 steps for biking approx 20 miles.
