06-21-2019 09:02
06-21-2019 09:02
So frustrated. Anyone have this problem. Did a soft reset. Removed the device. Did a hard reset. Did a factory reset. Nothing. Is there a satellite problem? Soooooo frustrated. Have had 3 runs now not tracked. Jeeeeeez!!
06-22-2019 15:07
06-22-2019 15:07
It's great to see you around @brandi97. Thank you for the troubleshooting tried.
Fitbit Ionic has built-in GPS. When you select a GPS exercise, Ionic vibrates when it finds a GPS signal. Environmental factors including tall buildings, dense forest, steep hills, and even thick cloud cover can interfere with your watch's ability to connect to GPS satellites.
For best results, wait for Ionic to find the signal before you start your workout. However, if you don't want to wait you can start your workout and GPS tracking begins when Ionic finds a signal.
Note that Ionic uses your step count to calculate distance until it finds a GPS signal. The total distance calculated for a workout may be slightly less accurate when GPS data isn't available for the entire time. For more information, see How accurate is GPS?
Let me know how it goes!
Best Answer08-08-2019 06:54
08-08-2019 06:54
Yes... I’m having a lot of issues connecting to GPS. Missed out on an OCR Race with no connection the entire time. Did 5 miles at the beach yesterday and no connection the entire time..... my daily runs in between are hit and miss......did yours start to work again.
Best Answer08-08-2019 07:18
08-08-2019 07:18
I've had my ionic for 8 weeks now and it's never connected to any GPS satellites...I have to use my phone every run walk or bike ride. I'm getting tired of this. Never had this problem with my surge. So I figured an updated watch would be better but of course no...
No dense trees. No tall buildings. No mountains. No excuse.
08-09-2019 11:21
08-09-2019 11:21
Thanks for participating in the forums @Dbb91f. I appreciate the details mentioned. I've shared your post with our Support team and they've mentioned you already have a case with them, please continue the communication through email, they will continue assisting you.
It's great to see you around @CycleGreig. Thanks for the details mentioned and for the troubleshooting tried before.
1. GPS can continue tracking while your phone is locked.
2. The location services are enabled within your privacy settings. Make sure to have the "High accuracy" option selected.
3. You have a strong Internet signal (Mobile Data) during the run
Also, try force quitting the app before tracking another activity.
Best Answer08-11-2019 00:01
08-11-2019 00:01
Best Answer08-11-2019 02:07
08-11-2019 02:07
@SilviaFitbit are you sure you replied to the right thread? Ionic doesn't have connected GPS and it looks like this is what you described 😉
@CycleGreig I encountered same problem multiple times. It helps to stop and restart tracking although it doesn't guarantee success. There is not much you can do as a user. If your mobile phone can connect and watch cannot then the problem is the watch. One thing that may help is not to move while Ionic tries to acquire GPS. For me, this issue appeared this year. Before, I have never had problems with connection except that it could take up to 1 minute. I suspect Ionic doesn't store and update GPS location cache hence the problems with connection (not enough storage?). Garmin with outdated cache file may also make you go crazy.
08-11-2019 04:51
08-11-2019 04:51
Best Answer08-11-2019 05:20
08-11-2019 05:20
So I've had my ionic for over a year now. God would take sometime to connect on runs sometimes but I don't think I never had it connect at all until yesterday. I do the same 1.5mile circuit so all that jazz about tall buildings, trees, etc, yeah unless someone erected a Faraday cage around my development the day before yesterday, nope. I,ve factory reset the watch and I'm still searching for GPS. So if you buggered the GPS software, just ownup to it please Fitbit!
08-12-2019 03:42
08-12-2019 03:42
So what was the point of spending 300 bucks on a watch that doesn't track my GPS? And with the Fitbit app, I cannot track my cycling, only walk run or hike? So now I have to use another app to track cycling? Basically just a fancy heart rate monitor and step counter...I'm so disappointed....
08-15-2019 14:39
08-15-2019 14:39
Hey everyone! Sorry for the delayed reply.
Thank you for getting back @CycleGreig. Sorry to hear you're experiencing this with your Ionic. You should be able to use your Ionic to track your activities. In this case, I've shared your post with our Support team and they will continue assisting you.
It's great to see you around @t.parker. Sorry about the troubleshooting posted above, as you mentioned the steps mentioned above are just for connected GPS and for Ionic which has built-in GPS. Thanks for sharing your tips.
Thanks for the troubleshooting done @Dbb91f. Hope you can continue enjoying your Ionic.
It's great to see you around @msg270. It's pretty weird that your Ionic's GPS isn't working. I've shared your post with our Support team and they will continue assisting you.
Best Answer08-15-2019 16:54
08-15-2019 16:54
My Ionic also can't connect to GPS. This just started last week. I've had it for at least a year and a half and have never had issues connecting to GPS
Best Answer08-16-2019 04:51
08-16-2019 04:51
Best Answer08-16-2019 07:45
08-16-2019 07:45
I have the same problem. And it hasn’t Worked since yesterday.
08-18-2019 16:19
08-18-2019 16:19
I've tried both a factory reset and hard reset with no luck.
Best Answer08-21-2019 16:03 - edited 08-21-2019 16:03
Hey there @Tony_F_369 and @Dbb91f. Sorry for the delayed reply.
Thank you for getting back @Tony_F_369. Sorry to hear that you just started having issues. I've shared your post with our Support team and they've mentioned you already have a case with them, please continue the communication through email.
I'm glad to hear that it started working for you now @Dbb91f. I would like you to make sure you've tried the troubleshooting mentioned above.
Keep me posted! I'll be around if you need further assistance.
