03-11-2018
07:57
16:54
RicardoFitbit
03-11-2018
07:57
16:54
RicardoFitbit
The entire reason I bought the Ionic is because it has a dedicated GPS chip inside the device, meaning regardless of my phone reception, my run should be tracked via the dedicated GPS, well I've been on a few runs now and the watch gets stuck on "Connecting..." and it never connects to the GPS which is a bummer because I don't want to have to take this back and spend an addition $300
Moderator edit: Word choice
11-07-2020 14:40
11-07-2020 14:40
Concur I have a third party metal strap and it interferes with initial GPS connection. I simply take the strap off and it locks in less than s minute. Then reconnect the strap and in good to go. By the way when I leave the metal strap on it never connects to GPS. So glad you recommended taking it off. I love my Ionic!
12-09-2020 17:25
12-09-2020 17:25
It's too bad they don't seem to be continuing with the Ionic range. Pushing GPS users to the Sense. I like the fact the Ionic looks different to the Apple Watch but hey-ho, will most likely move with the masses to the Sense when my Ionic finally gives up (I'll do my best to keep the Ionic running for as long as possible).
12-13-2020 00:41
12-13-2020 00:41
I have the same problem it started dropping out through a ride and now it will not find the GPS at all tried rebooting the phone and the watch reloading the app and still nothing for the money you pay for these things there should be better backup 🤔🤬
06-01-2021 12:07
06-01-2021 12:07
I have stood in front of my home waiting and hoping for the satellites to light up my Ionic and nope so signal
06-01-2021 12:29 - edited 06-01-2021 12:29
Hi bgolden
check earlier in this feed for troubleshooting. Particularly if you’re using a replacement watch strap….
