03-11-2018
07:57
16:54
RicardoFitbit
03-11-2018
07:57
16:54
RicardoFitbit
The entire reason I bought the Ionic is because it has a dedicated GPS chip inside the device, meaning regardless of my phone reception, my run should be tracked via the dedicated GPS, well I've been on a few runs now and the watch gets stuck on "Connecting..." and it never connects to the GPS which is a bummer because I don't want to have to take this back and spend an addition $300
Moderator edit: Word choice
03-11-2018 09:24
03-11-2018 09:24
@SlipperySix This is usually because of the gps not knowing where it is and having to poll all available satellites rather than knowing which satellites to actually look for before calculating its position. This takes a lot longer than when doing a start when the gps has a rough idea of where it is.
The process is quicker if you keep the Ionic stationary the first time it tries this, as moving it further complicates the process. Once done, subsequent start ups should be quicker
03-11-2018 09:24
03-11-2018 09:24
03-11-2018 09:33
03-11-2018 09:33
I set it outside on the ground for about 10 minutes while it was connecting and it finally did. I went out back into an exercise and the GPS connected much faster after that. Thanks for the input friend!
03-17-2018 17:03
03-17-2018 17:03
Thanks this worked!
08-22-2018 08:26
08-22-2018 08:26
Mine regularly loses reception on a run and fails to reconnect unless I stop and wait.
08-23-2018 07:02
08-23-2018 07:02
This. All the time and it is beyond frustrating.
It connects right away but then a half mile in to my run it just disconnects. Clear skies and no trees in sight.
08-23-2018 07:12
08-23-2018 07:12
And again... 😞
Lost GPS reception multiple times yesterday while out running. Today again on my bike. Clear skies and no obstruction.
Decided to bite the bullet and switch to Garmin - ordered a Fenix 5 Plus this afternoon. So after 2.5 years (and an Ionic, Aria and Surge later), it's adiós Fitbit!
08-23-2018 08:34
08-23-2018 08:34
And once again!
This afternoon's run. Took a few minutes to reacquire a GPS lock. Seems to be dropping off almost every activity now.
10-09-2018 00:06
10-09-2018 00:06
Since i have bought Ionic, i have run two 10K marathons, both the time it lost GPS connection. At first one it calculated 9.58km and on second run it never connected after 6km. I cannot stop during a marathon. Yes i started running only after GPS was connected. Please help fix this.
12-02-2018
06:33
17:21
AlexandraFitbit
12-02-2018
06:33
17:21
AlexandraFitbit
Buller..Buller?
Anybody?
Im having this issue as well
Send me your ionic?
Moderator Edition: Format
12-03-2018 00:45
12-03-2018 00:45
My problem was fixed after i did this. Before every run I shutdown and start ionic. No it doesnt disconnect.
12-05-2018 10:14
12-05-2018 10:14
@preshx18 I'm so glad to hear that the problem was resolved. Thank you for posting the update here. Don't hesitate to get back if you see something unusual and I'll be glad to help you.
@Superruss Thank you for joining us in this thread! I'm sorry to hear that your Fitbit Ionic GPS lost connection. I would like to follow up on this and would like to know if the issue persists or if it got resolved. Also, there are times that cloudy weather may affect the connection, also tall buildings.
If you see that the issue persists, please restart your tracker as described in this help article and try another activity using the GPS connection and see if the issue gets resolved.
Keep me posted on the outcome! ![]()
12-19-2018 20:03
12-19-2018 20:03
Wait, I'm having the same problem, what did you do to fix it?
12-19-2018 22:26
12-19-2018 22:26
@Jjic wrote:Wait, I'm having the same problem, what did you do to fix it?
Yes, I bought a Garmin Fenix 5 Plus.
12-19-2018 22:32
12-19-2018 22:32
12-19-2018 22:35
12-19-2018 22:35
That's good to hear @preshx18.
Best Answer02-20-2019 06:57
02-20-2019 06:57
This is really starting to 'rustle my jimmies', I bought this watch because one of the key features was in-built GPS so I don't have to bring my phone along on runs. I find myself having to wait 15-20m every time pre-run just so it finds my location.
Multime restarts, factory resets, re-syncs, nothing seems to help this issue. I'm currently waiting 15m with it sat outside trying to find the loc...
02-20-2019 16:06
02-20-2019 16:06
Best Answer02-21-2019 11:27
02-21-2019 11:27
Best Answer02-22-2019 15:56
02-22-2019 15:56
