01-02-2019 19:12
01-02-2019 19:12
My Ionic keeps displaying the Screen Awake and Notification Settings, and vibrates when they are displayed. It seems no matter what I do, they reappear and the Ionic vibrates. I did a factory reset, which caused it to update the software/firmware. I also removed the Ionic from my iPhone Xs and re-added it. None of these steps have stopped the problem. This is really frustrating. I've had it for a year and it seemed to work fine until a recent software/firmware update. Does anyone have a resolution for this issue?
01-03-2019 03:16
01-03-2019 03:16
So no solution but I’m having the same problem
09-13-2019 22:18
09-13-2019 22:18
Any solution? Mine started doing this today.
Best Answer09-13-2019 23:01
09-13-2019 23:01
Best Answer09-14-2019 08:04
09-14-2019 08:04
09-14-2019 14:26
09-14-2019 14:26
Thanks so much, I contacted Fitbit and they're sending a replacement - I appreciate your response as it was very frustrating.
