05-20-2018 18:48
05-20-2018 18:48
on the current update and suddenly i cannot get 24hrs of battery out of my ionic, anyone having these issues?
05-20-2018 19:01
05-20-2018 19:01
Have you tried restarting your Ionic? Do it several times and then charge fully and see how it goes. Let us know
Helen | Western Australia
05-20-2018 20:05
05-20-2018 20:05
I'm with Tempest on this one. This just started for me about a week ago. The OS2 fixes do not seem to work. Few days ago I had a problem connecting my Ionic back to my phone after a phone reset. I'm on version 27.32.10.15. Now it dies after 2 days. I've never really used it for anything other than bpm and steps. Could the third party watch faces be the culprit as that seems to be the only thing anybody changes. I've deleted app, and data, factory reset Ionic. Will post in the morning with my findings.
05-21-2018 01:00
05-21-2018 01:00
I was getting 4 days out of my previous Ionic... It was replaced because of GPS issues..
The replacement is averaging 5-6 days, wearing 24/7 some Workouts, the occasional GPS and charging from 24% on the PC USB charger tp 99% most times.. About 90 minutes to charge..
05-21-2018 11:51
05-21-2018 11:51
Ok, unpaired from phone (pixel 2 xl) deleted app, factory reset phone, shutdown, then used button combo to reboot. Repaired to phone and changed watchface to a stock fitbit watch face. It's now 1450 and my fitbit ionic is showing 82%. Was 87% when I woke up this morning. So it lost more charge overnight than it has all day today. Only thing I did after factory reset was reconnect wifi. Everything else is still stock, no extra apps. Maybe the 3rd party watch faces are the battery bandits.
Best Answer05-21-2018 16:11
05-21-2018 16:11
u have tried and still no luck with this battery life
05-21-2018 16:12
05-21-2018 16:12
the battery dies while i'm asleep! i am not even doing anything
Best Answer05-21-2018 16:16
05-21-2018 16:16
I use the Fitbit watch face "Ace" and on my previous Ionic I used Nautical. No battery issues.
Best Answer05-21-2018 16:36
05-21-2018 16:36
Are those 2 watch faces presented by fitbit or a 3rd party themer?
Best Answer05-21-2018 16:46 - edited 05-21-2018 17:23
@KwamGary wrote:Are those 2 watch faces presented by fitbit or a 3rd party themer?
Fitbit.. Analog.
The Ace shows my HR, steps etc when I tap on the face, also the date at the top.
Best Answer05-21-2018 17:11
05-21-2018 17:11
After the newest update my ionic will not charge. I never had any problems charging before
Best Answer05-21-2018 17:15
05-21-2018 17:15
Best Answer05-28-2018 15:31
05-28-2018 15:31
i am using all out of the box apps and faces.
my only solution so far is i charge the ionic 2x in a 24hr period.
Best Answer05-28-2018 22:50
05-28-2018 22:50
now the ionic only holds a 100% charge for about 12hrs 32mins.
Best Answer05-28-2018 23:11 - edited 05-29-2018 03:43
I have the Iconic and am having severe battery issues as well. I used to get 4 days out of it. After the recent firmware update I'm lucky to get 6 hours. I have GPS turned off and have restarted it multiple times. I really like using the sleep features but now the watch will die during sleep even if it was 100% charged when i went to bed. This has rendered my Ionic useless. Very frustrating.
05-28-2018 23:42
05-28-2018 23:42
@DjLaZaRuS wrote:I have the Iconic and am having severe battery issues as well. I used to get 4 days out of it. After the recent firmware update I'm lucky 6 hours. I have GPS turned off and have restarted it multiple times. I really like using the sleep features but now the watch will die during sleep even if it was 100% charged when i went to bed. This has rendered my Ionic useless. Very frustrating.
i completely agree with you! sleep function is awesome but the battery life makes it useless!!!!
wonder if they will replace this device!
anyone from fitbit support reading this?!
06-06-2018 18:38
06-06-2018 18:38
Ok so here's my results, I'm finally fed up with this thing. $300 and I can't get it to keep a charge more than 2 days. After 2 days no matter what it says the battery lvl is, the watch dies within hours. When I put it on the charger, it will no longer pair to my pixel 2 xl. So I have to unpair the watch and start the setup process all over again. My only question at this point is how do you request a refund.?
06-06-2018 19:14
06-06-2018 19:14
Just a thought. Has anybody else switched to the metal band with the magnetic clasp? This may just be coincidence, but i think my problems started not long after I changed bands. But then again. The OS2 update was about the same time.
Best Answer06-06-2018 20:58 - edited 06-06-2018 20:59
I would definatly recommend anybody experiencing problems with your battery to contact Fitbit support. Most likely your battery is defective and they will replace it with a new one.
06-06-2018 21:02
06-06-2018 21:02
