02-05-2019
05:37
13:07
RicardoFitbit
02-05-2019
05:37
13:07
RicardoFitbit
My Ionic has been acting strange I had to turn off Bluetooth many times to get it to resync and it wasn't easy at all, but I would get it to work at times then it would not work or sync again, I recently had to reset back to default, everything looked good. Now today I woke up and it is dead it isn't even turning on. I am guessing it is dead! So last March is when I bought it, this sux. I do use it I bike every week!
I got the protection from Bestbuy I wonder what they will do? Anyone else have issues?
02-05-2019 21:48
02-05-2019 21:48
I have the same problem. Two days ago my ionic stopped syncing. Tonight i talked with Fitbit support about the syncing issue. I did a factory reset and now it is completely dead. Fitbits have a 1yr warranty so you should be able to get yours replaced through Fitbit support. Unfortunately mine is out of warranty so they won’t replace it. Every Fitbit tracker I have had never lasts more than a year and a few months so I won’t be buying a new Fitbit to replace my broken ionic.
02-08-2019 02:40
02-08-2019 02:40
Yes mine also died and fitbit support after a few useless attempts washed their hands off the issue! I will never buy a fit**ahem** again
02-08-2019 02:41
02-08-2019 02:41
I am also finalle going Apple no more fit**ahem**!
02-08-2019 07:04
02-08-2019 07:04
Life span is about 6 months on average. I had 4 watches, two for me and two for my wife. All four of them lasted about 6 months before screen failure.
02-09-2019 03:46 - last edited on 02-27-2020 16:07 by LiliyaFitbit
How can fitbit justify this?
02-09-2019 04:02
02-09-2019 04:02
**ahem** I really had hi hopes for FITBIT. I have their penny stocks just waiting for it to explode! **ahem** I guess I will go back to Garmin then once this second one dies.. I will respond to this post when it does. The new one tho is still acting stupid too. Sometime s. It won't sync
02-19-2019 13:35
02-19-2019 13:35
Fitbit should refund my money!
02-19-2019 14:08
02-19-2019 14:08
Mine died after 14 months... FB wouldn't replace it because warranty period was 12.
02-20-2019 07:09
02-20-2019 07:09
02-20-2019 07:22
02-20-2019 07:22
04-11-2019 10:23
04-11-2019 10:23
After about 18 months my Fitbit Ionic just stopped working. It had been working fine up until it just died. I bought it from BestBuy with the protection plan so it was replaced but I was told that Fitbit no longer allows BestBuy to cover their watches with the protection plan so now I am debating if this is something I want to keep. If a $300 products just stops functioning shortly after the manufacture's warranty wears off then what is the point of the tracker if something goes wrong. I will not spend the money to replace this if it goes out again for no reason. I have 15 days to decide before I am locked in. Has anyone else been dealing with the short life span of Ionic watches?
04-11-2019 10:56
04-11-2019 10:56
04-11-2019 13:56
04-11-2019 13:56
04-11-2019 17:40
04-11-2019 17:40
You just pretty much explained my situation to a T!!! I haven't read any of your responses yet so I am praying that by the end your problem was solved and that you're happy with the results! Finngers crossed🤞🏻🤞🏻😌
04-11-2019 17:47
04-11-2019 17:47
04-11-2019 21:06 - edited 04-11-2019 21:07
Jamie how is the Apple Watch what do you use it for is it water proof does the battery last long. ?
05-01-2019 05:52
05-01-2019 05:52
Yes, The exact thing happened to me. I did a factory reset about the time my watch turned a year old and today at a year and five month I woke up to it completely off and it will not turn back on. I contacted support and after an attempt to do a factory reset on it, we determined that it was dead. They offered me a 25% discount on a new tracker.
05-01-2019 07:03
05-01-2019 07:03
There is something wrong with the software, because I see more and more people with dead Ionics after trying a factory reset(including myself). Whatever you do, don't do a factory reset for now unless this is your last resort. Better wait for the next software version.
05-01-2019 07:08 - last edited on 02-27-2020 16:05 by LiliyaFitbit
Which you obviously told them to shove?
