10-20-2018
09:10
14:13
YojanaFitbit
10-20-2018
09:10
14:13
YojanaFitbit
I've had my ionic for about a year now and I'm getting increasingly frustrated with it. The watch will not connect to the app or phone for days at a time. I end up having to go through setting it it every time. I thought with the system updates this issue would have been fixed by now but I am left very disappointed.
Moderator edit: Updated subject for clarity.
What platform are you using?
one cruise ship at a time!Same with me. Constantly have to go through all the their stupid steps to get my watch to sync. For nearly $300.00 you would think the watch would sync properly. Never buying a Fitbit product again. I will stick to a basic fitness watch that will work. I am about ready to just chuck this Ionic watch in the garbage. Having to do the steps everyday is a pain and I waste of my time. Very disappointed with my Ionic watch.
I had similar problems with an Ionic I purchased about a month ago. It was constantly losing it's ability to connect via wifi and bluetooth, and In a fit of frustration, I deleted the fitbit app from my phone and installed it on a tablet which isn't paired with any other bluetooth devices. That was five days ago. I suspected that since my phone is paired to multiple bluetooth devices, perhaps the competition from other bluetooth devices might be the trigger for the Ionic's syncing malfunction. For the last five days, the problem has not reappeared. It seems a little nuts that in order for the Ionic to properly function, you have to use a separate bluetooth enabled tablet without any other paired devices on it. However, since moving the app to the tablet and reinstalling the Ionic on that device, there hasn't been a problem. Before that, the Ionic was losing it's ability to sync daily.
I'm happy to see you here guys, please receive a warm welcome all new member of the Community Forums! ![]()
Thanks for the steps that you've already tried. If you're constantly having syncing issues. You can try to log out/in from the App or restart "Bluetooth". Once you've done that to Force sync your tracker Tap on "Account" in the Fitbit App, then tap on your "Ionic" picture and find the option "Sync now" to force sync.
In case of having an Android phone, also check your phone Permissions and leave location on to keep syncing and getting notifications with your phone, for more info check this suggestions from @ErickFitbit. ![]()
If that doesn't work let's check some requirements that your phone and Ionic should have in order to successfully communicate:
Requirements:
If the syncing issue remains with a mobile device I would recommend following the steps below:
Hope this helps and welcome again! ![]()
