09-08-2021
05:34
06:03
AlvaroFitbit
09-08-2021
05:34
06:03
AlvaroFitbit
Hello
it s been several Times that ionic don t charge.
in spite of many tries describe on the forum it keeps light off
need help
thanks
06:07
05:31
09-08-2021
06:07
05:31
@Manu06 I hope you're doing well!
Not sure which steps you have tried so I want to confirm that you have checked the instructions in this help article to help your Ionic charge.
Hope this helps.
Best AnswerThanks alvaro
i try all the solutions but it dosen t work unfortunatly
what s next?
thanks for your support
manu
Best AnswerI have the same issue with my Ionic since mid Aug, I did as suggested as per list. I have now the constant bright Fitbit logo, the battery icon shows charging , but my Ionic is NOT charging. Not even after plugged in and lit up for hours , the app on my android EF 20 sees my Ionic suggest to install the available firmware but due to low battery power it won't etc etc.. Fitbit / Google is not helping. I am really NOT happy Google.
09-08-2021
10:24
05:31
09-08-2021
10:24
05:31
@SunsetRunner Thanks for stopping by.
Thank you for trying the suggestions in the previous post. Since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around.
