04-09-2019 01:07
04-09-2019 01:07
Ionic 4 month old not charging, tried with customer support different usb ports, cleaning connectors, factory reset.. Still no luck.. any other suggestions?
04-10-2019
11:15
06:22
04-10-2019
11:15
06:22
@K.Loza Welcome to the Fitbit Community! It's great to have you here!
I will gladly assist you with this issue and thank you for troubleshooting this issue. It seems that you have tried most of the suggested troubleshoots. I would only add to try a different charging cable (maybe from a friend or relative so you don't need to buy one). If the issue persist then please keep up the communication with Support to find a solution.
Let me know how it goes.
Best Answer04-10-2019 11:55
04-10-2019 11:55
Try reading the posts about the Ionic not turning on. This sounds like to many other people having the same issue.
Best Answer04-11-2019 10:52 - edited 02-28-2026 11:14
Welcome to the Fitbit Community @BopperXIII! If your Ionic is not charging properly despite some steps you've may tried, please take a look at the help article Why isn't my battery charging? and follow the instructions provide there.
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. What may actually cause damage to the tracker's battery (either on a computer or a wall adapter) is the charging time, which if excessive over time may damage the battery and therefore cause quick battery drain or prevent the tracker from charging at all.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know if you need anything else!
