10-02-2018 00:01
10-02-2018 00:01
10-02-2018 00:31
10-02-2018 00:31
It's tricky putting forward new ideas without knowing what you have tried so far.
The usual things to try when you get syncing issues are:
If you've tried all those without luck then, as it says in the troubleshooting guide, it's time to contact customer support. If they can't fix then they can advise you on your warranty options.
10-02-2018 09:38
10-02-2018 09:38
I am having same trouble started on the 29th sSeptember been told by help desk it is my Samsung J5 phone that is now incompatible after 6 months of no issues??
