Ionic stuck on 0% and won't charge
ANSWERED
My ionic was working great and then the battery died the other day. I plugged it in to charge and came back a few hours later and it still says 0% when you press a button. It has now been on charge for 3 days and still says 0%. I have tried wall chargers and running it off the laptop USB but still nothing! I can't reset or do anything as there is no battery life! Help!
660 REPLIES 660
Same problem here.   It happened once before and a hard reset worked for about another two months, now I'm back to the same issue and nothing works this time.  I called tech support and after several attempts at doing the same thing, they basically told me to buy a new one.  It is only 18 months old.  Good luck with customer support.  I hope their responses to you are better than I received.
Thanks for replying! I tried that and everything! I even called Fitbit and they walked me through some fixes. They finally said they would give me 20% off of a New Ionic! My last hope was trying a new charger which I did. IT WORKED! So, that’s one thing for everyone to try before giving up!
Sent from my iPhone
It's great to hear that the new charger worked and it was not the watch!
@Pameshelman,
I've said this on a few posts. The different charger you tried probably had a higher current (amperage) output that was enough to "kickstart" an aging battery that dropped too low in volts. As these batteries age it's important NOT to let the battery drain below 5 or 10% before charging. A new battery can handle it, but with an older battery the Ionic doesn't know the true battery condition - so the device can suddenly power off due to a depleted battery even though it reports it as still having a few percent charge left.
Unfortunately, I never saw that info re the charger.  The person from Fitbit should have told me, though!  Yes, I still have issues if I let the battery drop too low.  So, I try to charge my ionic as soon as the "low battery" comes on.  Thank you!
Have had the ionic for 5 days. Tried to charge last night and it wouldn’t charge. Cleaned contacts, tried different wall outlets, factory reset, etc. and it won’t get past the 0% screen. Very disappointing. At this point best to return to store?
Absolutely. This is a known problem with Fitbits and the company won't do
**ahem** to fix it. You'll get a new one under warranty but it will eventually
quit a year from now when it's out of warranty. Fitbit makes **ahem**
products. Return it and get a Garmin
I did contact tech support and after various trials and rebooting both iPhone, watch, it now is working. But it’s 5 days. That doesn’t give me a great deal of confidence in the product.
When it on charge I held all three buttons down and it came on.
Hope this helps!
My fitbit arrived earlier today and hasn't moved off of 0% charge despite 6+ hours of trying with different outlets, cleaning the pins, trying to connect to my phone, trying restarts etc. Can this be fixed or should it just be returned?
Can’t be fixed.
When it is new it can’t be . I’ve had a few!
If you wipe it and it works and then it stops working , it will probably be
fickle
Thanks
Moderator Edit: Personal info removed
Return it. Fitbit knows about this problem and has done nothing to correct
it. Once you watch is out of warranty you will have a paperweight.
I ended up returning mine. I worked with customer service and after a couple hours it started working but considering I owned it 5 days I decided to swap out for the Apple Watch 3 and couldn’t be happier.
Regards,
Drew Fober
Hi, I just bought a new fitbit versa 2 and have the same problem.
I got from USA and arrived with 0% battery. Its charging for hours and still at 0%...
Is there anything that can be done?
With the versa doubl check you squeeze the sides of the charger and
completely sit the unit in it before closing. Make sure the pins are lined
up. It'll say charging in blue and show a status bar if working otherwise
return as defective
Explain something for me. If the Ionic won't charge how does plugging it in(which should charge it, but doesn't) and then trying to turn on a dead device solve any problems. There is no charge and it is not taking a charge. Try again.
It doesnt solve it. It usually never works again.
Thanks
Ended up binning it and buying another one, third time I have had to do this! Looks like that is how they make money, these things are obviously designed to only last so long before having to be replaced!
For mine it was pure luck. I did the same thing multiple times with no luck, then suddenly it responded. Again, after four or five days of ownership this simply cannot happen. Spells trouble ahead.
Regards,
Drew
Holding down all 3 buttons brought my Ionic back to life, charging now, thanks.
