03-14-2020 14:07
03-14-2020 14:07
hello I need help my Fitbit ionic does not turn on and I already tried to restart it and nothing appears on the screen and when I connect it to the charger nothing appears on the screen I don't know if it's broken
Best Answer03-18-2020 12:02
03-18-2020 12:02
Hi, @Madrem1_w , did the battery die completely before this happened? Sometimes that can make your Fitbit unresponsive. I would suggest putting it on to charge, even if it does not appear to be charging (but do make sure that it is a working charging plug). Give it a good two hours to charge and then try the reset again. You may have to hold the buttons for longer than the suggested time, or repeat the procedure several times.
Let us know how it goes. Welcome to the forums!
Best Answer03-19-2020 03:07
03-19-2020 03:07
Left on charger overnight still will not turn on
