01-04-2018
18:32
12:15
01-04-2018
18:32
12:15
t is impossible to figure out the most straightforward things like string an alarm.
Best Answer01-04-2018 19:31 - edited 01-04-2018 19:48
@R.white wrote:The ionic May be the worst product ever. It is impossible to figure out the most straightforward things like string an alarm. The online documents are HORRIFIC. I am about 10 minutes from retuning this p.o.s. garmin is WAY better.
Hi @R.white,
Sorry to hear that. Not sure what you mean by "string an alarm"? Do you mean chain together a series of alarms?
You may find this thread informative about alarms.
Also, in terms of worst watch and interface, Timex gets my vote:
Best Answer01-05-2018 03:31
01-05-2018 03:31
I meant setting an alarm. I misspelled setting and my iPhone changed it to string.
The user interface for this watch is perhaps the worst UI I’ve ever experienced. It is not intuitive at all. Jumping back and forth from watch to phone to get things configured or setup is beyond annoying. And Fitbit made it impossible to find anything close to acceptable documentation. The design and development team should be embarrassed.
Best Answer01-05-2018 04:01 - edited 01-05-2018 04:02
While I have yet to use the alarm in practice, I accepted your challenge of attempting this impossible task.
Step 1. Tap alarm icon
Step 2. Tap new alarm
Step 3. Set time and days desired
Alarm is set. If what I have just described is considered impossible then I'm led to believe that your expectations are a tad excessive.
Perhaps that timex may be a better choice.
01-05-2018 05:47
01-05-2018 05:47
@SimonRJ wrote:While I have yet to use the alarm in practice, I accepted your challenge of attempting this impossible task.
I agree, I didn't think setting an alarm could be any simpler really 🤔
As for the whole user interface, I wouldn't say it differs much from a modern smartphone (ios/android). Icons on a screen, swipe left and right between screens and tap Icon to open desired app. Certainly doesn't take much thinking about.
01-05-2018 07:25
01-05-2018 07:25
Not to pile on, but I use the Alarms App regularly for medication reminders, morning wake-up alarm that only wakes me up (and not my wife), one-off alarms, etc. Very simple, intuitive interface in my opinion, and works perfectly every time since the last firmware update was deployed. The only enhancement that I could see being beneficial is the ability to name each alarm, but that is not prohibiting my ability to use alarms. I would be interested in more specific details regarding the issues you are having with the native Alarms App.
