09-30-2017 07:33
09-30-2017 07:33
Hi folks,
Anyone else have issues with notifications on their Ionic? I'm on a OnePlus 5 here.
I find that after a few hours, notifications stop piping through to the watch. Normal sync is fine, and I've excluded the Fitbit app from battery optimisation and enabled the permanent notification and constant connection.
The only way for me to restore notification is to shut down and restart the watch.
So frustrating!
10-24-2017 11:54
10-24-2017 11:54
Better than missing notifications!
Nevertheless I get it.
Best Answer10-24-2017 12:37
10-24-2017 12:37
Only had mine for less tha 24 hours but once i stopped the Do Not Disturb mode on my Pixel XL so far so good...still prefer the Gear S3 but i can live with the Ionic. I never used the majority of features on the S3 and the App Store was not that great. I was a big fun of Pebble and maybe some of that will carry on here?
Best Answer10-29-2017 17:05
10-29-2017 17:05
This was it! I spent a couple hours doing EVERYTHING else, and all I had to do was fix this little feature.. not sure how it got turned off in the first place. Must have done it in my sleep I guess.
Thanks
Best Answer10-29-2017 17:16
10-29-2017 17:16
On android ...
Settings -> Apps and notifications -> App Info -> Fitbit -> App Notifications -> Override Do Not Disturb = On.
Best Answer10-30-2017 02:24
10-30-2017 02:24
What feature did you chabge. You never saud what it was.
Best Answer10-30-2017 07:36
10-30-2017 07:36
I FINALLY FIGURED IT OUT!!!! Go to the Ionic on your app, go to general and click on Notifications. When checking all of the notifications you want to recieve, make sure to click on the Fitbit selection. and it should show you specific notifications that you will recieve!
Best Answer10-30-2017 08:11 - edited 10-30-2017 08:30
Last night I was trying to pair bluetooth headphones, today I noticed on the watch that "Notification: Receive from phone" was off, I never went anywhere near this setting. Something to watch out for.
11-13-2017 16:58
11-13-2017 16:58
Thank you! I had tried everything else that was suggested on this and several other threads and none of those worked but this (Swipe Left and make “Notifications” set for “Receive from Phone”) finally fixed it! No idea how it got changed in the first place, but I am relieved to have found a solution. Thanks!!!
11-14-2017 03:44
11-14-2017 03:44
I am still struggling with it. DND is off, all day sync is off. Always connected off. I try turning Bluetooth on and off device on and off in several combination. I replaced to a new Ionic as well. It works for 3 or 4 hours and then stops.
Interesting is Test notification works well all the time. So I am sure it is something to do with sw
Is there a standard step by step procedure anyone can help with
Xiomi note 4 Android 7
11-14-2017 04:28
11-14-2017 04:28
App may have upgraded. Reboot phone and watch.
Best Answer11-14-2017 05:02
11-14-2017 05:02
Best Answer11-14-2017 05:04
11-14-2017 05:04
Best Answer11-14-2017 08:41
11-14-2017 08:41
I never did get my Ionic / Oneplus3 to work consistently, so I took the Ionic back to the shop.
I have now bought a Garmin Vivoactive 3, which worked with my Oneplus 3 straight out of the box, first time. Very Impressed, although the wristband is a bit short!
Best Answer11-14-2017 13:44
11-14-2017 13:44
Search surge band broken. 3 years and not fixed. Ionic will be no better.
My surge hasn't synched with my phone for over a year. Samsung.
Best Answer11-14-2017 16:19 - edited 11-14-2017 16:20
I have used the ionic on my Note 8, Pixel 2 XL, and iPhone X and the difference in experience is shocking. I can't believe how badly it works with Android and how well it works with iOS. I figured it would be the opposite.
On the note 8:
Had to pair ionic in "classic" mode all the time and music controls would still not work correctly or at all (no now playing information)
The apps I would setup for notifications would reset and go random on reboot.
Notifications arrive late or not at all
Can't accept or reject incoming call, just says you are getting one.
iPhone X:
Everything works like it is supposed to.
Don't have to pair ionic in classic mode to get music controls to work. They just do
Notifications work properly for apps that have been setup.
Can answer or reject incoming call from wrist.
So weird how this product works better on iPhone.
Best Answer11-14-2017 18:44
11-14-2017 18:44
@Mattvan87 wrote:I have used the ionic on my Note 8, Pixel 2 XL, and iPhone X and the difference in experience is shocking. I can't believe how badly it works with Android and how well it works with iOS. I figured it would be the opposite.
On the note 8:
iPhone X:
On the Pixel you need to disable all day sync and always connected. I'll stop write here as I've written this about a million times in these forums it seems. Cheers.
11-14-2017 23:16
11-14-2017 23:16
@SunsetRunnerI agree it is brand based. I had a Motorola moto x and it all worked pretty well. With samsung the fitbit is a brick on my arm. I have to synch with my laptop. 😞
Best Answer12-17-2017 10:56
12-17-2017 10:56
Had this issue, the way I replied it was turning off do not disturb, or "priority only"
Best Answer12-17-2017 11:16
12-17-2017 11:16
Best Answer01-12-2018 06:01
01-12-2018 06:01
Hi,
iphone 6s,
I've had to shut down my fibit every time notifications stop coming through and then they resume as normal. However this is really annoying and would love fitbit to release a bug fix, I believe the problem may be when turning on night mode on the iPhone when going to bed and it not recognising when you turn it off in the morning and this is when they stop coming through.
its really frustrating to restart the watch everyday !
