05-24-2019 08:37
05-24-2019 08:37
My Fitbit occasionally drains fully overnight. In normal use I charge it every day while I shower and it's usually in the high 80-low 90 percent range. On five occasions I've checked it and it's at 0%. I can't find any pattern to this. It's often at night while I'm sleeping. (sleep tracking was a big reason for getting Fitbit) I doubt that I'm activating this as I'm very sensitive to light while I'm sleeping.
I've tried the regular troubleshooting tips, including changing to a Fitbit supplied face and doing the factory reset. Nothing stops this occasional problem.
Best Answer06-17-2019 13:33
06-17-2019 13:33
17:34
10:08
06-18-2019
17:34
10:08
Thanks for getting back @Fred27. It's pretty weird that the battery is draining when you're not wearing your Ionic. I've shared your post with our Support team, they will continue assisting you.
Best Answer10-21-2019 17:03
10-21-2019 17:03
Is this still happening for you? Has it been resolved yet? I'm having the same problems but it's every few weeks that I wake up and the battery is completely drained. I had a full charge two days ago and it's been bleeding its charge. I'm down to less than 25% right now and I've done some quick charging in the mornings.
Best Answer10-21-2019 17:08
10-21-2019 17:08
12:16
10:07
10-23-2019
12:16
10:07
@Tomas8660 Welcome to the Community. Thanks for the details mentioned.
In this case, I've shared your post with our Support team and they've mentioned you already have a case with them please continue the communication through email, they will continue assisting you.
Thanks for your updates, @Fred27.
